Ganador Mirror installation help
Old Dec 8, 2007 | 10:33 AM
Chebosto's Avatar
Chebosto
Default Ganador Mirror installation help
can someone please post the Ganador instructions/wiring diagram for the Z or G?
need to figure out which wires to splice from factory harness to the Ganadors.
Mirrors have four wires (oem only has three)
1 - brown
2 - black
3 - blue
4 - black
2 and 3 are connected. i'm thinking this is the (+)? and the brown is (-) and the black #4 is ground. is this correct?
PumpedVA, VOlk350z. anyone? thanks
-cheston
Old Dec 8, 2007 | 08:57 PM
Marty_G's Avatar
Marty_G
Ask Howard@Technosquare since he installed a ganador mirror recently on a g35 which is basically a Z ganador mirror.
Old Dec 8, 2007 | 11:42 PM
Chebosto's Avatar
Chebosto
i figured it out. i didnt want to bother howard...
OK
OEM side harness, three pin connector:
Driver & passenger side on 2003 track model,
Pink Yellow and Blue.
Pink goes to Pin connector 2 & 3 on Ganador, (common ground for both motors)
Yellow goes to pin connector 4. This controls LEFT RIGHT movement.
Blue wire goes to pin connector 1. This controls UP DOWN movement.
man. what a PITA... oh well. i got it done.
Old Dec 9, 2007 | 06:32 AM
240zx's Avatar
240zx
Good for you! Now post some pictures of your car with them on!
Old Dec 9, 2007 | 06:34 AM
teh215's Avatar
teh215
Any comments on how these compare to stock? I thought about picking up a set several months ago...
Old Dec 9, 2007 | 08:39 AM
Chebosto's Avatar
Chebosto
visibility wise, they're smaller so if you're used to seeing your rear fender and then other lane, then you might have a little hard time adjusting mentally for these.
i decided to change from my Autotechnic mirrors cuz my roomate who parks next to me in the garage or people at work keep bumping into my passenger side mirror and its a PITA to adjust manually.
weight comparison, these are about the same as stock. i picked mine up used, hence the slightly longer than usual install time. i dunno how the new kits come if they're 'plug-n-play' if they are, then yea. probably a 20 minute install job each side.
picts of the harness:
(note 2 & 3 are common ground for both motors)
stock harness
here's a pict of the 4 pin connector adapter i made (0.100" 4 pin female i got at Fry's Electronics.)
my black wire is to connected to pin 2&3, which goto purple on OEM.
my red wire is connected to pin 1, and blue on OEM (up down)
my green wire is connected pin 4, and yellow on OEM (left right)
22 AWG wire throughout, solder w/ resin flux and e-tape it all up.
Old Dec 9, 2007 | 09:55 AM
teh215's Avatar
teh215
^^^ Thanks! Any more pics?
Old Dec 9, 2007 | 10:13 AM
PumpedVA's Avatar
PumpedVA
Wish I could help bro but I just cut my wires LOL With my seat all the way back and them being RHD I cant see dick out of them anyway
Old Sep 18, 2012 | 03:37 AM
sofa king's Avatar
sofa king
I know many people won't use this but thanks to chebosto for the pics.
Old Sep 18, 2012 | 12:50 PM
Chebosto's Avatar
Chebosto
glad it worked out for you
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
