headlight question
Old Dec 18, 2007 | 06:24 PM
dsmZ's Avatar
dsmZ
Default headlight question
hey someone recently hit my vehicle and now im looking for headlights. i saw on ebay they have just the housings available and its stated that its for a halogen/non hid equipped vehicle. my question is: since i already have hids on my vehicle, can i get these type of lights and just "plug-and-play" my hids into them? or is there a different bracket or something on the housings themselves ? thanx!!
http://cgi.ebay.com/ebaymotors/HEADL...sid=p1638.m118
Old Dec 19, 2007 | 03:31 AM
bamyi's Avatar
bamyi
I'm almost positive that it would be a plug and play. There is only one quick-connect in the back of the headlight unit that plugs in. In order to remove the headlight, you must first remove the bumper, then it's cake after that.
Old Dec 20, 2007 | 02:18 PM
dsmZ's Avatar
dsmZ
thanx! bumper will be off anyway because that needs to be replaced as well!
Old Dec 20, 2007 | 08:42 PM
bamyi's Avatar
bamyi
You'll need a 10mm ranch for the four bolts that holds the headlight unit in. The wire for the quick connect is very short so you can't lift the headlights out very far. I found it easy to use a very long flathead screw driver for the driver's side. the passenger side, you have enough room to reach down, hence you'll need a very short screwdriver.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
