Gauge Installation
Old Jan 7, 2008 | 05:55 PM
Torched Z's Avatar
Torched Z
Default Gauge Installation
i was needing some help on installing my newly acquired air fuel gauge. I searched but could not find anything helpful! Only pictures of what people have in there car. I just want a little help on where to connect the wires too. I also have a boost gauge that i will take advice on where to tap into
Thank you,
Torched
Old Jan 7, 2008 | 05:56 PM
iStan's Avatar
iStan
ZR
Connect the AF sensor wire to the gauge wire?
For Boost, T Tap into the line that runs to the Bypass Valve?
Old Jan 7, 2008 | 10:54 PM
Torched Z's Avatar
Torched Z
im not sure i understand what your saying....Wire to what gauge? I apologize sincerely.
Please help me out!
Old Jan 7, 2008 | 11:20 PM
iStan's Avatar
iStan
ZR
I think I am as confused as you. What AF gauge is it?
Old Jan 8, 2008 | 10:32 AM
Torched Z's Avatar
Torched Z
i have an air fuel ratio gauge. Z-Series from autometer, its electronic and i think that sums it all up. i installed one on my Grand Prix GTP when i had that but it cam with a harness that tapped directly to the O2 sensor. so im confused with this car.
hope that helps
Old Jan 8, 2008 | 11:47 AM
eez's Avatar
eez
hope that helps
the gage didn't come with an o2 sensor? Usually you will weld in a new bung, install a new o2 sensor and connect it to the AFR gage. Esp if it's a wideband, since I don't think 03's have wideband o2's.
For the boost gage see below
Old Jan 8, 2008 | 11:51 AM
SpoilsofWar's Avatar
SpoilsofWar
Are you talking about the sensor wire or the power & ground wires?
Old Jan 8, 2008 | 09:17 PM
Torched Z's Avatar
Torched Z
i know what to do with the power and ground. But there are a white and a violet wire that im not 100% sure where they go. The Violet one is the signal wire between the connector and the PCM. The white is for the 12V dash lighting.
Hope that will solve the problem!! :/
Old Mar 15, 2008 | 04:53 PM
Torched Z's Avatar
Torched Z
well figured out the boost guage. Now i need to figure out to install my air fuel guage! Where do the wires go?
Old Mar 15, 2008 | 07:25 PM
merlin3's Avatar
merlin3
if it's just a regular autometer a/f gauge don't even bother installing it as it's just something pretty to look at and not accurate. Buy a real wideband like aem or innovate.
Old Mar 16, 2008 | 09:03 PM
Torched Z's Avatar
Torched Z
well i have the gauge so im going to use it. I know its not accurate but like you said it looks pretty. Anyone know where to tap into? I know theres another guy on here thats looking for the samething......who's going to be the hero?
Old May 18, 2008 | 03:40 PM
jolt3500's Avatar
jolt3500
Could someone post pictures ASAP? I have been searching for a good place to connect my a/f gauge. Thanks.
Old May 18, 2008 | 05:06 PM
SpoilsofWar
Is it a narrowband?
Old May 18, 2008 | 05:20 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
This gauge will not accuratly give you AF please do not use it to tune your car, you will blow your engine. If you just want a dumby gauge by all means install it.
As for the wiring... easiest if you plan on installing on a pillar is to tap into the fues block in the drivers kick, otherwise if you are like me and install them in the center consol, the wiring is simple through the stereo. As for the sensors and what not, the wiring isnt hard, should only be 2 wires from your O2 sensor. Just follow the instructions.
Old Jun 26, 2009 | 07:11 PM
SharpShooter23's Avatar
SharpShooter23
Bump! I am getting ready to install my glowshift narrowband AF gauge. Bought it used from a friend and it didnt come with instructions. Anybody have a link or anything to point me in the right way? Thanks (Search did not come up with anything)
Old Jun 27, 2009 | 06:53 AM
SharpShooter23
anybody?
Old Jun 28, 2009 | 09:05 AM
SharpShooter23
Come on I know somebody has installed gauges on there Z.. Help a brother out.
