what goes in all these blanks? '07 Enth
Originally Posted by mega_boi
the nismo's have the plaque that says nismo and has the serial number of each car on there.
not too sure about the others though.
and it would be cool if the subwoofer thing was a cubby.
Guessing here...
Picture 1 is the switch for the seat warmers on the Touring Model.
Picture 3 is for the switch that lowers the top on the Roadster.
No idea about Pictures 2 and 4.
DId you open the cover behind the drivers seat? That is where I mounted my sub, the correct cover says Bose & can be had at your local stealership I think I paid $10.00 for the cover
Originally Posted by 350ZTheStandard
DId you open the cover behind the drivers seat? That is where I mounted my sub, the correct cover says Bose & can be had at your local stealership I think I pau $10.00 for the cover
As for 3, that is a null blank, there is nothing that goes there.
Has anyone modified their blank on picture 1? I am thinking of placing a switch and buttons there.
I do want to (when i eventually put in a stereo) mount a couple of amps in there... but it would have been nice to have it more accessible/finished as a cubby.
Originally Posted by DrDave83
Number 2 above the rear view:
that's the bluetooth and mic - for my GT
In pic 1 the seat heaters go there. Yet in my car theres a 3rd button which im not sure about. 2 Is a mic if you had bluetooth. 3 is blank on mine too. I assume one if for the top and the other for VDC. And that cubby, you just get your fingers in there and pull. Clips hold it in I think. Or use a screwdriver but wrap it so you dont scratch the plastic, if you had the bose youd laugh at the sub, its weird looking, like inverted.
yeah .. i have an 07 and by the shifter is the seat warmers but I only have 2 seats 2 switches .. so I always wondered WHY the 3rd blank switch ?
on 07s the tcs/vdc and the next is the top goes down button the the ZR
Originally Posted by sintaxeror
How do you open it?
Good luck on whatever you decide to do
Also if you have the heated seats you will notice there is room for another switch. I believe it is used as a spot to mount the switch for the Euro spec rear fog light. Some countries in the EU require it. Im not completely sure though.
Originally Posted by TheProfessional
+1 that is a good spot for an amp and electronics, plenty of work space and the cover is a great ventilator.
Not true!!! That spot is for if you have the VDC.
Originally Posted by z350boy
IF YOU WANT A CUBBY THERE GET A JDM ONE.
It was a pain dealing with the Nissan dealership for part numbers (before they started all the cool online stuff at Courtesy) but the install was an easy afternoon's worth of work.
