What do you think of the "Zee-Bracket"??
Anyone have a Zeebracket installed for their front plate? Will it fit on an 08 and do you still have to drill holes to mount it?? Any good pics other than what's on their website would be appreciated.
http://www.zeebracket.com/
I've gotten stopped twice for no front plates, but I keep my front plate and a bracket in the car and every time I got pulled over I told the cop I just bought the bracket and going home to put it on
Worked every time
Worked every time
Worked every time
Worked every time
I could do the same but I don't even have a bracket, thankfully I haven't gotten pulled yet
Originally Posted by Slidewayznizmo
I don't like it. It blocks too much airflow to the lower grille. It needs to be mounted higher like the original.
Originally Posted by badbee
Good point. To those who have the bracket, does it block too much air flow and, I assume you still have to drill some holes??
My intake is off-center on the drivers side.
That plate does block the air. If you were racing the car on a track it could overheat, of course you wouldn't race with a plate in front of the grille anyways. I'm going to custom make one for my nismo z to go where the tow hook is. It will have to be long enough and only a third of the plate will block the grille area.
You can flip the Z-bracket 180 degrees and the plate will mount higher up and clear of the air intake so no airflow is blocked. It will clear the bumper cover by about 3/4-1 inch and not damage the paint. Installed it that way on our '03 and on our '06 (till we changed the nose, anyways)
Originally Posted by Z Tuned
IIRC, it screws into the factory tow hook location, so no drilling is required.
The Stillen one screws into tow hook. I have that for '06, and it sits out far enough that I don't think it will impede airflow to anything. But, even with the lock-tite on it, I have to level it once a year (it sometimes get knocked askew)
Originally Posted by gr8scott_o
ZeeBracket doesn't look to screw into tow hook. Instead, it looks like it attaches to the grill itself. Looks like it is quite close to the grill, and I could see it blocking airflow.
Thanks,
