VeilSide Problems....
Old Jun 16, 2003 | 06:15 PM
React3's Avatar
React3
Default VeilSide Problems....
DAMN!!!!!!!!!!!!!! I installed my Veilside Front Lip today, first off the Carbonfiber version is soooo damn tight, their is abosolutely no flex.. So what happens, I break the edges tring to fit it properly about half inch on both sides..and also a slight crack in the middle of the kit... Im so freakin pissed... my question is .... 1. Can I fix this?? 2. Do I return this? 3. What can I do???
Thanks
Old Jun 17, 2003 | 03:20 AM
React3's Avatar
React3
OK 71 views and no responses..that sucks...
Old Jun 17, 2003 | 05:54 AM
ColecatZ's Avatar
ColecatZ
ask a couple bodyshops in your area......they should be able to repair it. a few others have done similar already.....
Old Jun 17, 2003 | 06:09 AM
React3's Avatar
React3
thanks for the reply
Old Jun 17, 2003 | 06:15 AM
ColecatZ's Avatar
ColecatZ
check with bodyshops in your area, they should be able to repair it......others have done the same.
Old Jun 17, 2003 | 06:46 AM
BJF2K's Avatar
BJF2K
If you have the time and don't have the cash, you should return it... also write a letter and tell them what a poor quality this sweet kit has... or else.. just spend more money to repair it, but find a experienced body shop to do this... or else ...hahaha.. you know what will happen.
there is my 4 cents input... good luck
Old Jun 17, 2003 | 03:09 PM
micky's Avatar
micky
Default Sorry too hear that...
Me! I just spent over $4000 on installation and repair fiber glass. My bumper craked 4 times now. Each time I have to spend $400 to $600 to fix and repaint whole bumper. For Fact fiber glass could get fix, but carbon fiber... not sure, but i will find out soon for you.
Old Jun 17, 2003 | 03:42 PM
1200tt's Avatar
1200tt
sounds like cracked clear coat. that should be an easy fix. Because the kit fits so tight, you have to be very careful when mounting it.
Old Jun 17, 2003 | 05:21 PM
React3's Avatar
React3
I got off the phone with Veilside , I was complaining about the kit and the tight fitman .. The guy was all defensive and saying " I sold 90 kits and I never had a complaint" this and that... anyway Veilside is working on a poly kit that's supposed to be this wierd material it's gonna be released in a couple months...
Old Jun 17, 2003 | 05:45 PM
micky's Avatar
micky
Default No~ clear coat crakes!!!
I will post up the picture later. You will be so amaze! 10 out of 10! If it was clear coat crake, I will be happiest man on earth. I really hate fiber glass!!!
Old Jun 18, 2003 | 01:59 PM
mrrsx350z's Avatar
mrrsx350z
Do this; get some dyno spray, it’s like dynomat but in a can, spray on the inside, this spray act like a compound that keep thing like fiberglass and carbon fiber from break. And if it do crack, the crack will not don't spread threw out the hold kit. The only down fall is that it make your kit heavy and sometime it don't fit at all. To do it your self you have to be, you have to be pretty handy to get an even coat. If you want to try this out go to your local stereo shop and ask them about the spray. And in order to fix the CF lip you have to get a CF pad that have the same design. It's like tape; you just match the checker design. Then you clear coat it. I guy I use to know did that for my CF lip on my RSX. You can't even tell. It lasted for a while until I hit something on the freeway. So I threw away the kit. So if want to know where to get the CF peace, you should go to a plastic store, they should have something like that. If they don't have it you should get some raw CF material, that where I got mine. So good luck!
Old Jun 18, 2003 | 05:23 PM
knihc2008's Avatar
knihc2008
first, post pictures.
Old Jun 18, 2003 | 05:31 PM
shaneotool's Avatar
shaneotool
Man, I don't like to hear this, I've wanted this lip for a while, but I've heard too many stories about them cracking or arriving chipped.
Now I don't know if I should get it, which sucks, cause I thinks it looks boss.
Old Jun 18, 2003 | 08:04 PM
micky's Avatar
micky
Default Don't get wrong.
Body kits(Version 1 or 3) looks real good. You will fall love into it. But Keep in one piece is very hard. Tomorrow I will post up the pictures(all the problem areas). I just came from vaction.
LunchBox20
Oct 20, 2015 10:22 PM
Dymsi
Sep 29, 2015 11:32 AM
Importlife.com
Jan 1, 2003 09:49 AM
valuetl
Dec 30, 2002 01:23 PM
