gotta push the trunk button twice
Old Feb 2, 2008 | 12:32 PM
DukeEntDotCom's Avatar
DukeEntDotCom
blah
There are new springs from Nissan that are supposed to fix this. I bought them, but I still have to put em on.
The penny trick stops working after a while, and if you put too many coins you will dent your hatch.
See Service Bulletin here: http://www.nissanhelp.com/Ownership/.../NTB04-042.htm
Old Feb 2, 2008 | 03:28 PM
henry j's Avatar
henry j
^ that sux i was about to do the penny thing too. i guess its not such a big deal for me to have to do the penny trick, but i jus figured that everytime i clean the car, touch or play wit the springs the trunk seems to work fine for about 2-3 times.. weirdd lol
Old Feb 2, 2008 | 03:52 PM
350ZTheStandard's Avatar
350ZTheStandard
Men & Women this could not be any easier,
just hold the button for 2 or 3 seconds until the hatch pops open. Even in the cold weather this always works for me, my struts are approx 3 years old & no problems.
Save the change for the collection plate at church!!!
Old Feb 3, 2008 | 08:00 AM
ZKansasZ's Avatar
ZKansasZ
rather to use the change for car...imo
Old Feb 3, 2008 | 09:28 AM
DukeEntDotCom
blah
Installed the new springs last night, and the hatch pops open NO PROBLEMS. They are worth it to me...the two pop thing is annoying, esp. when my hands are full and it's raining outside...lol...
I bought my springs here:
http://www.trademotion.com/partlocat...=3&catalogid=2
Old Feb 3, 2008 | 11:39 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
I'm assuming these are sold as singles, not as pairs?
Old Feb 3, 2008 | 12:51 PM
Chad68's Avatar
Chad68
Mine gets worse and worse and have to do it twice now too. That's why I don't use the hatch
Old Feb 3, 2008 | 01:13 PM
JungleJunkee's Avatar
JungleJunkee
when i press my button it unlocks but doesn't even lift up...I have to physically slip my fingers in the groove and press the button and lift to get it open...would that be a spring issue as well? I have an 03 touring
Old Feb 3, 2008 | 01:57 PM
bizcotch's Avatar
bizcotch
have you checked under the liftgate for the springs?
Old Feb 3, 2008 | 09:00 PM
gruntysmasher's Avatar
gruntysmasher
The springs look like rubber stoppers halfway up the hatch. There are two small plateau-like areas on the body for the springs to rest on.
There is a Nissan recall on the springs, so any dealer should be able to get you the parts/parts codes.
It takes about twenty seconds to change them. Do that, and your problem should be fixed.
Old Feb 4, 2008 | 06:00 AM
DukeEntDotCom
blah
Correct.
Old Feb 4, 2008 | 09:02 AM
07JimmyZ's Avatar
07JimmyZ
the reason you have to press it twice is because theres two locks on the latch, I was told for safety reasons. If there's not enough pressure on struts(worn out or whatever) they won't get past one or both of the locks. I have the mastergrade hatch and until they release new struts(can only use one strut), I have to hit the button then pull the hatch up while I hit the button again for it to release. I believe JTabraham(I think thats how its spelled) is selling heavy duty struts that hold up well.
Old Feb 4, 2008 | 09:42 AM
black350's Avatar
black350
the link with the spring prices isn't bad at all. i called the dealer and they wanted a little less than 40 bucks a peice! im going to check pepboys or something first to compare prices, hopefully theyll atleast have something similar lol. ill get back to yall asap.
Old Feb 4, 2008 | 10:14 AM
black350's Avatar
black350
so yea...their computers dont list anything supposedly.
Old Feb 4, 2008 | 04:07 PM
DukeEntDotCom
blah
Then why is it that I changed my springs and my hatch opens with one press of the release?
Old Feb 4, 2008 | 04:27 PM
Nihsnek's Avatar
Nihsnek
Sic 'Em
Lol, I have to do this as well...
A pain..i'm going to try the "penny" trick tonight.
Old Feb 5, 2008 | 04:59 AM
Greedy4nismo's Avatar
Greedy4nismo
glad this works for you, oh master of the knowledge. the rest of us have tried this, and it still doesn't work. nice try though.
Old Feb 5, 2008 | 04:47 PM
  #38
DukeEntDotCom
blah
LMAO
Old Feb 6, 2008 | 07:41 PM
  #39
350ZTheStandard
Going to guess it is a bit warmwer here in NM vs: Indiana. I do like the o master of the knowledge part minus the sarcasm part
Old Feb 7, 2008 | 08:12 AM
  #40
crkextra's Avatar
crkextra
Gees.......just get a small tube of Silicon Grease and smear a LIGHT coating on the hatch seal after you clean (you know, the black foamy gasket.......), keep the area clean that the seal touches on the body and done...........
IT'S THE SEAL STICKING TO THE BODY that prevents the hatch from opening........
Fbody owners knew about this YEARS ago....their hatches were heavier also.
C.R.
