so i get my clear corner reflectors in the mail and...
Old Feb 14, 2008 | 12:23 PM
nismo53E's Avatar
nismo53E
Default so i get my clear corner reflectors in the mail and...
i didn't realize how much of a pain in the *** these things will be to install. am i missing something here? it seems to me the only way to do it is to remove the entire front bumper. dammit. instructions? i did a search....
it's a nismo front end if that makes any difference. thanks!
Old Feb 14, 2008 | 12:46 PM
hndumafia's Avatar
hndumafia
taking off the front bumper is one way to do it, and some will say the easiest. instead, i turned the wheels as much as possible (to the left for the left side, and vice versa), pulled off the plastic fender liner till i could reach the are, and replaced the reflectors like that. the passenger side is quite a bit harder because of the windshield washer fluid reservoir, but with some patience, and a small ratcheting screw driver, it is possible.
Old Feb 14, 2008 | 12:56 PM
Sick Z's Avatar
Sick Z
+1, I used a small stubby screwdriver on passenger side. A little patience and you'll get it!
Old Feb 14, 2008 | 12:57 PM
noodleman's Avatar
noodleman
i undid parts of the bumper for the passenger side, and pulled it out abit so I could reach the reflector. When I helped my friend install his, it was definitely easier to install by pulling the bumper off...takes about the same amount of time, except you don' t have to roll around the ground conturting your arm to reach that thing.
Old Feb 14, 2008 | 12:59 PM
iStan's Avatar
iStan
ZR
I think I can take my bumper off blindfolded now with the car on the ground. It's really easy and a lot more painless to do so.
Otherwise, Stubby screw driver, funky positions, scratched to sht arms, and you'll get it done.
Old Feb 14, 2008 | 01:44 PM
east1999bt's Avatar
east1999bt
any difference between the nismo z front end and other z's?
350zDex's Avatar
350zDex
The right side is really easy just take the wheel off and the cover and there it is two screws. The left side is a little hard instead of taking the bumper half way off i just took the washer bottle off with three bolts very easy.
Old Feb 14, 2008 | 01:45 PM
iStan's Avatar
iStan
ZR
I believe so, but I have never been up close and personal with a nismo, so not 100%
Old Feb 14, 2008 | 02:02 PM
noodleman's Avatar
noodleman
if anything the nismo Z's install looks easier..it's closer to the wheelwell then the stock design.
Old Feb 14, 2008 | 02:10 PM
KYEXTAZ's Avatar
KYEXTAZ
take the bumper off..much easier..unless you like your knuckles banged to hell
Old Feb 14, 2008 | 03:41 PM
md350's Avatar
md350
After trying to reach in there for a while, I loosened the bumper and pulled it back a little to get down there on each side. In hindsight it would have been much easier to do this to begin with or take the entire bumper off, which really isn't very difficult. Trying to reach all the way in there on the passenger side was a waste of time and blood.
Old Feb 14, 2008 | 03:48 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
+1 I have taken that front bumper so many times but sometime taking those damn plastic fasteners is a b1tch if they get stuck............
Old Feb 14, 2008 | 07:49 PM
usmanasif's Avatar
usmanasif
I have trouble believing that. Check the DIY section for DIY help.
Old Feb 14, 2008 | 07:55 PM
blazed54's Avatar
blazed54
do you need to take off the tires to remove bumper?
Old Feb 14, 2008 | 08:45 PM
Elohite's Avatar
Elohite
take off the front bumper... takes like 10-15 minutes
Old Feb 14, 2008 | 09:09 PM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
I installed mine this way:
https://my350z.com/forum/showthread....ear+reflectors
Notice what Paul said: the passenger side is a PITA b/c of the windshield washer resovor and a right angle philip screwdriver....so true.
Or you can remove the splash shield under the motor to get access to them. If you do your own oil change....this should be easy.
