Whats the easiest way to get to the headlights for changing???
I want to change the 5-watt wedge bulb, but I dont want to remove my whole bottom bumber housing or anything like that, how else can I get to the headlights???
If you jack up the car, remove the front wheel, it is the plastic piece that keeps water from splashing into the front bumper. I think there are 3 10mm bolts on the underside of the bumber, 1 phillips screw along the edge of the wheel well, and 3 of those plastic push clips inside the wheel well.
Hope this helps.
Ian
Hope this helps.
Ian
Yeah thats helps, but let me ask you something, when you take the wheel off, when I put it back on im kinda worried about the nuts not being tight enough, will my hardest turning make it tight enough, or should I use a mechanical tool to put the nuts back in?
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
