Steering Wheels
Old Apr 12, 2008 | 05:13 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Question Steering Wheels
What type/brand do you all recommend? What all is needed to replace the OEM wheel? How easy/difficult is it to replace? Thanks.
Old Apr 12, 2008 | 05:24 AM
Jon70ProofZ's Avatar
Jon70ProofZ
check here https://my350z.com/forum/showthread.php?t=350221
Old Apr 12, 2008 | 01:59 PM
Ruthless18x's Avatar
Ruthless18x
Yeah there are a couple picture threads going on ^
I think all you need is a hub and release, like Works Bell.
I really like the Nismo wheel from Japan without the airbag, Vertex, and Keys.
Old Apr 12, 2008 | 02:36 PM
Vader007's Avatar
Vader007
What ever wheel you get, make sure to get the Works Bell hub!!!!!
Old Apr 12, 2008 | 02:40 PM
Crom's Avatar
Crom
Don't forget the 2 resistors as well...about 10 bucks a peice. -- make sure there plugged in correctly. When you take the wheel off, have a buddy hold the base so it doesn't spin around so you you can line up the marks correctly....thats it - GL...Oh yeh and the lamest part are the torque bolts - the WB hub comes w/ the right wrench.
Old Apr 12, 2008 | 03:04 PM
Chad68's Avatar
Chad68
Those torque bit bolts aren't all that bad.....
I almost removed my stock wheel without completly destroying it, errrrr.
Wrench that comes with the kit FTL. Do yourself a favor and go to Sears and get the socket/ratchet tamper torx bit.
Old Apr 13, 2008 | 04:23 PM
Abishop's Avatar
Abishop
ADA! LOOK! HE'S NOT DONE MODDING! ha ha ha ha
Old Apr 13, 2008 | 04:54 PM
Moroccan_Mole's Avatar
Moroccan_Mole
if you buy it from Z1 it comes with all of the needed accessories (torx bit and both resistors)
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
