HID Conversion Kit installtion questions with pics:
Old May 6, 2008 | 01:39 PM
Asian Invasian's Avatar
Asian Invasian
Default HID Conversion Kit installtion questions with pics:
Pics are a few posts down:
Old May 6, 2008 | 01:41 PM
usmanasif's Avatar
usmanasif
The harness snakes around the headlight and plugs into the big light gray connector right underneath each light. It is the only piece of wiring on/around the headlights. What blub are you plugging into it? Are you trying to splice into factory wiring? I assume it isn't just a bulb replacement issue.
Old May 6, 2008 | 01:42 PM
Nic@CiNcity's Avatar
Nic@CiNcity
The headlight harness is ON the headlight. If you need to plug a bulb into it, the plug should be right there... on the headlight.... where the bulb goes... I think that's what you're asking??
Old May 6, 2008 | 01:49 PM
Asian Invasian
Thats what I though that big grey connector was. The only problem is that my instructions says: "plug directly to the cars OEM wire hanress (plug from the halogen bulb) and I have no idea what that is talking about.
Old May 6, 2008 | 01:55 PM
usmanasif's Avatar
usmanasif
So you're trying to replace the headlight bulb? Just remove the old one from behind the headlight and plug the new one in.
Old May 6, 2008 | 01:59 PM
Asian Invasian
LOL no, im installing HID conversion kit. I already put the 8000k bulb into where it should be. I am going to get pictures for you guys. brb
Old May 6, 2008 | 02:17 PM
Asian Invasian
Ok I pluged in my Bulb already, and I am wondering where to plug these two butt connectors into? I am assuming they go into this black piece where the OEM non HID Bulb goes into?
On the other side of those butt connectors is this:
The guide says to plug this into the OEM factory headlight harness, I don't know where that is.. that was my original question.
Since I have pictures now anyway I had a another question: Out of my relay harness there is this:
Where do I connect this as well?
Old May 6, 2008 | 02:41 PM
Asian Invasian
Anyone? I need this done by tonight lol..
Old May 6, 2008 | 03:03 PM
Asian Invasian
Nevermind I figured it out.
issyz
Jul 2, 2017 03:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
