NEW Gauge Pod for the Z!!!
Mar 10, 2012 | 02:05 PM
Perfect!!!!!!!
Thanks so much!
Mar 10, 2012 | 03:03 PM
Would you like it out of a different material?
Mar 10, 2012 | 03:06 PM
Have you got something dark? I was going to paint it but if possible that would be great.
Thanks!
Mar 10, 2012 | 03:17 PM
I dont have anything dark. I could send you some vinyl to glue onto it.
I was thinking a plastic material or a thin CF laminate.
Mar 10, 2012 | 03:21 PM
Would it be possible for you to cut the holes into the vinyl?
I can just paint it if it's too much to ask.
Thanks
Mar 10, 2012 | 03:59 PM
Nah, the vinyl is too soft, it would just wad up.
Thought about getting a vinyl cutting machine, could definitely do it with that.......hmm
Mar 10, 2012 | 04:47 PM
I'll paint it. I really appreciate your hard work!
Mar 10, 2012 | 04:58 PM
did the other plate fit on the front?
Mar 10, 2012 | 05:22 PM
It fits but the door won't close. It needs to go a bit further in.
I wanted the one inside so it's perfect.
Thanks
Mar 13, 2012 | 04:01 PM
Hoping to get them installed this weekend.
Mar 16, 2012 | 05:48 PM
1,000,000 thanks CUX350Z!!
Installed the AFR and 80% of the oil temp & pressure gauges. They came with the wrong harnesses .
Mar 26, 2012 | 01:33 PM
Oil temp & pressure are in. Temp did not get above 140. Damn pressure gauge stays pinned at 100. Ordered a 140 psi gauge.
Apr 6, 2012 | 06:04 PM
Made a few out of MDF
Triple Gauge, Flush face full cubby for my 2003. I recessed my AEM gauge since the face is so tall i can no longer close the cubby lid. Now i can! I will be getting the AEM oil temp gauge soon as well so at least 2 of my gauges match.
This is a recessed plate for a cubby box that I did for Flo-rida.
MDF is so much easier to cut! E30, if you want one out of MDf let me know.
Apr 6, 2012 | 06:06 PM
I'd love one.
That is how it looks now.
Thanks
Apr 8, 2012 | 06:23 AM
Apr 8, 2012 | 08:27 AM
I installed mine, took only a few minutes after the paint dried.
I can finally shut the cubby again! Aem gauges are fatter and taller than most others. On my previous setup i was able to close the cubby but when i switched to the AEM boost i was screwed.
Apr 8, 2012 | 08:29 AM
Apr 14, 2012 | 10:20 AM
mdf version
Apr 14, 2012 | 11:08 AM
May 18, 2012 | 08:19 AM
