Xenon 12K HID Kit
Old May 11, 2008 | 12:40 PM
jmccartney's Avatar
jmccartney
Default Xenon 12K HID Kit
Anyone know if this kit is to hot and could possibly melt the stock housing?
Old May 11, 2008 | 01:02 PM
krnzzang84's Avatar
krnzzang84
i don't recomend higher than 8k-9k
Old May 11, 2008 | 03:51 PM
joe645733's Avatar
joe645733
`people will guess ur driving a civic from a distance.
Old May 11, 2008 | 03:52 PM
Z04's Avatar
Z04
you won't see crap at night. stick with the lower numbers
Old May 11, 2008 | 04:31 PM
Escobar's Avatar
Escobar
anything above 6k you are going to have trouble seeing, they are for looks.
Old May 11, 2008 | 04:38 PM
ExBF Material's Avatar
ExBF Material
...with 12k HID's your mancard will definitely be revoked tryin' to look hot on the streets with those purplish/pinkish lights of yours.
Old May 11, 2008 | 06:25 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Consider the STi JDM replica clear lens swap mod if you're interested in getting a MUCH better light output with fantastic cut off using your stock HIDs. I have the lenses if you need a set and are able to DIY. Other wise, like mentioned above, stay away from anything above 6k IMO.
Old May 11, 2008 | 07:13 PM
Changvi's Avatar
Changvi
Please don't tell us that you plan to put that garbage on your Z...
Old May 11, 2008 | 07:22 PM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
Why not 16,000? Let's get some ****in pink HIDS! OHHH YEAAA!!!
Old May 12, 2008 | 05:08 AM
The Captain's Avatar
The Captain
I've seen that crap on a riced out Lexus IS. It was a sad sight...
Old May 12, 2008 | 05:21 AM
Al Kapwned's Avatar
Al Kapwned
The vehicle's wiring would probably start on fire in attempt to end it's own embarrassment.
Old May 12, 2008 | 06:51 AM
Z04's Avatar
Z04
+1
Old May 12, 2008 | 09:44 AM
Changvi's Avatar
Changvi
where is the op? he probably got too embarrassed to reply on here...
Old May 12, 2008 | 10:44 AM
Z04's Avatar
Z04
he is too busy making multiple threads about his wasted transmission
Old May 12, 2008 | 07:42 PM
jmccartney's Avatar
jmccartney
I tell you, I ask for a suggestion and get totally bashed. And this is suposed to be a forum? Unreal. I'm new to the 350z and trying to learn here so I can be a part of the gang. Forget it. . .
Old May 12, 2008 | 08:00 PM
gregom's Avatar
gregom
People will be jackasses thats just they way it is, ignore them an move on...
On a serious note, 12K is way too high unless you'll be using them for a show. Otherwise i'd stick in the 5000K or 6000K range if you want that bluish color. Above that and you start losing a good deal of light, and the headlamps on the Z aren't that great to begin with.
All HID's are pretty much the same in terms of temperature and such, there isn't much of a difference at all between the different color ranges. HID's don't generate as much heat as halogens so I don't think it will be a problem.
If you plan on actually driving around at night with the car I'd just stick some 5000K's in and be done with it. The more blue/purple you add the more rice you add. I know a lot of BMW's and such look like purple from a distance, but thats just because of the cutoff shield is bluring the light a bit so the color changes at the edge. If that's what you want you need to retrofit some different brand of projectors into your 350Z headlamp housings.
Old May 12, 2008 | 08:10 PM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
Originally Posted by dave079
K thanks bye
Old May 12, 2008 | 08:12 PM
350ZYALATA's Avatar
350ZYALATA
Tentill4z
Or you could get the STi cutoff lens.
Noobs training noobs.
