Took my Z to the car wash...
Old May 21, 2008 | 07:26 PM
hotfiyah's Avatar
hotfiyah
Question Took my Z to the car wash...
While at a gas station car wash, I was just chilling listening to music...when this appears to me.
I'm appalled
And yes....my windows were closed >_<
Old May 21, 2008 | 07:34 PM
Zetta33's Avatar
Zetta33
You ain't the only one man, that happens to me every once in a while when i take to the carwash. Probably ain't sealed right or something
Phantom Menace's Avatar
Phantom Menace
Were your doors closed all the way...there seems to be a gap from the door to the dash. You know how the window will roll down a cm or so when the doors don't close all the way? Either that or you need new weather stripping.
Old May 21, 2008 | 07:37 PM
hotfiyah's Avatar
hotfiyah
yeah, I know that little roll down, but it was only at that section, before the tweeter. Scared the crap outta me too, because I didn't want my diamond audio tweeters getting soaked.
Old May 21, 2008 | 07:39 PM
Anomaly's Avatar
Anomaly
Nothing to worry about.
Frameless windows tend to have some seepage occasionally.
Old May 21, 2008 | 07:46 PM
Phantom Menace
+1...that much water won't soak your tweets. Not good...but shouldn't ruin your speakers.
Old May 21, 2008 | 07:53 PM
CSF's Avatar
CSF
doesn't look like too much...should be ok
Old May 21, 2008 | 07:57 PM
hotfiyah's Avatar
hotfiyah
I wasn't too worried about it, but i'm glad that it's not something that is broken. appreciate the help guys.
Old May 21, 2008 | 08:02 PM
13SECZ's Avatar
13SECZ
Honestly...you really should bring your Z to the car wash..thats kind of your first mistake....Z's should be handwashed...
car wash + z = swirl marks.....
or if it was a brushless then it washes like s$it anyways...
Old May 21, 2008 | 08:05 PM
HKS-Z's Avatar
HKS-Z
Backroad Pro
high pressure adds to it-open both doors and take some cleaner(glass cleaner is fine)-and wipe the door seals.you'll find that can have a lot to do with it.
Old May 21, 2008 | 08:09 PM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
It happens when you take it through a high pressure washer....therefore:
handwash > car wash station
Old May 21, 2008 | 08:24 PM
hotfiyah's Avatar
hotfiyah
haha. yea...i've only taken it to a station wash twice in 5 months. That's why i've just discovered this.
Gotten lazy, and hand washing seems like back-breaking work now.
Old May 21, 2008 | 08:56 PM
Gary1107's Avatar
Gary1107
Sometimes I get hit with a drop of water like on my face or something when the water jets spin around the car...and I'm like WTF where is the water coming from..
Old May 21, 2008 | 09:06 PM
bamyi's Avatar
bamyi
It happens to both my doors. Here's what I think:
I have window motor problems with both my doors. Now when I close my doors, they don't inch up anymore, thus leaving a little gap for the water to get in.
Old May 21, 2008 | 10:17 PM
Sco2355's Avatar
Sco2355
I have this problem with my drivers door. I had it with my passenger door as well but I had the plastic piece above the window (which is on the roof, I suppose) fly off when I was on the interstate when I first got it. Come to find out the screws that are behind the weather stripping weren't going threw all the necessary pieces to keep it intact. Bought a new piece, used the old weather strip, and fastened it the correct way and I never had a problem again.
I believe that is also partially the problem with my drivers side because you can see a gap between the stripping and the frame, and the screws aren't going through all the right pieces. Plus my window isn't aligned on the drivers side so I get bad wind noise on that side. Just a good rain or a hose will cause water to seep in from the same spot, right above the tweeter.
I know it may sound a bit confusing but check it out. You'll know exactly what I mean when you see it. If this is the case the best thing to do is remove the weather stripping and plastic piece and adjust accordingly. Before trying you may want to buy new clips because they break EASILY.
Old May 22, 2008 | 02:33 AM
insomniaxvi's Avatar
insomniaxvi
Originally Posted by hotfiyah
While at a gas station car wash...
First mistake.
Old May 22, 2008 | 03:13 AM
350Zforlife's Avatar
350Zforlife
370Zforlife
My previous car also had just glass in the door so I had this problem ... what I used to do is that keep the car running, open the passenger door , with the up and down switch bring the glass all the way down and then up , slam the door real hard and then wash my car (in ur case, drive into the car wash place) ... you can try it next time if you want ...
Old May 22, 2008 | 06:18 AM
djnc's Avatar
djnc
Originally Posted by insomniaxvi
First mistake.
+1 LOL...i was going to say the same thing...not sure if the OP has aftermarket wheels, but those rails can scratch them...also its not the best for the crappy nissan OEM paint either
Old May 22, 2008 | 07:01 AM
The Captain's Avatar
The Captain
First mistake.
+1 Again.
High-pressure wash = fail.
Brush wash = fail.
Hand wash = teh win.
Old May 22, 2008 | 03:09 PM
haeshik's Avatar
haeshik
+1
