[Help!] Driver and Passenger side window issues
So My passenger side window has always struggled since I bought the Z..It struggles doing down, but goes up fine after It has gone down, sometimes I have to push the window down. Also sometimes it also does not go up after the door is closed, any idea on what could be causing this? Would a reprogram help?
Also my drivers side window has started to stop going up fully after I close the door. Strangely enough it also rolls half way down after I start the car sometimes, any idea on why?
Thanks!
Thanks!
hey how long has it been since you had your car because i had that problem too but i went to the dealer just under 12000 miles and it was under warranty and they said something was wrong with the window motor
Thanks!
Thanks!
So an update...before I can even get to open the door panel now my windows will not go up or down. Every once in a while I am able to raise the windows after I get in the car to make up the gap in the window for the entry and exit. What should I do? This is getting really annoying!
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
