My clear corner install write-up
Old Jun 3, 2008 | 06:50 AM
sintaxeror's Avatar
sintaxeror
Darnit.. ah well.. when the time comes I'll see if I can feed the wires down there without taking off the bumper but I guess we'll have to see. Thanks for the tips!
Old Jun 3, 2008 | 07:19 AM
07rdsterGT's Avatar
07rdsterGT
You may be able to feed them down there. I was figuring on the wires being attached to the corners and you having to feed them to the acc. circuit or however your hooking them up. Never-the-less, go ahead and follow my directions and look around and see if you can do it with out taking the bumper off. If you have to take it off, you’re already half way there anyway.
Old Jun 3, 2008 | 07:21 AM
sintaxeror's Avatar
sintaxeror
Originally Posted by 07rdsterGT
You may be able to feed them down there. I was figuring on the wires being attached tot he corners and you having to feed them to the acc. circuit or however your hooking them up. Never-the-less, go ahead and follow my directions and look around and see if you can do it with out the bumper off. If you have to take it off, you’re already half way there anyway.
Nah dude I am gangsta, I use connectors
Old Jun 3, 2008 | 07:24 AM
07rdsterGT's Avatar
07rdsterGT
Gangsta FTMFW nukka!
So I just found out these is a recall on 07 6MT's (slave cylinder)
Old Jun 3, 2008 | 09:31 AM
gothchick's Avatar
gothchick
no
Old Jun 3, 2008 | 09:36 AM
07rdsterGT's Avatar
07rdsterGT
yawn....
Old Jun 3, 2008 | 11:27 PM
finalforce's Avatar
finalforce
Thanks for the info, I kind of stayed away from this mod because I didn't want to go through the hassle and take off the bumper. I'm now re-considering the idea of swapping to clears
Old Jun 4, 2008 | 03:28 AM
07rdsterGT's Avatar
07rdsterGT
Glad MY thread could help you.
Old Jun 4, 2008 | 04:47 AM
driftmc's Avatar
driftmc
+1
Old Jun 4, 2008 | 04:48 AM
07rdsterGT's Avatar
07rdsterGT
Oh my. Hey z06, moral is rising pretty fast in this thread, but come in here and knock it down a peg.
Old Jun 4, 2008 | 04:55 AM
Beka Z's Avatar
Beka Z
I didn't remove my front bumper to change these either... Just used ramps to life my car enough for me to wiggle underneath- and stuck my arm between the wheel liner and the skid guard. The clear corners were very easy to remove and replace... it's a tight fit, but i have stick arms...if you have large arms and hands, this might not be the ideal way for you to do it.
Old Jun 4, 2008 | 05:14 AM
07rdsterGT's Avatar
07rdsterGT
Women working and getting dirty with 350z's = HOT
It doesn't get any better then that my friends
/end thread
Old Jun 4, 2008 | 05:52 AM
Big Tav's Avatar
Big Tav
What if you wanted them for an 04?
Old Jun 4, 2008 | 06:06 AM
07rdsterGT's Avatar
07rdsterGT
I would advise you to read the other threads cause my 07 is my first Z.
Old Jun 4, 2008 | 06:09 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by Z04
better than making a new thread and basically repeating what was done in a thread that was made two years ago then act like it was a new thing you discovered. good for you, you did one of the simplest mods that you can do for the Z.
https://my350z.com/forum/showpost.ph...7&postcount=50
and you even posted in that thread since it mentioned that you do not need to remover the bumper.
so basically repeating something that already exists is not contributing either.
Dude, STFU. His doesn't require you to take the bumper, wheel off which is a pain just to do reflectors. You DON'T need to do that. His is better than that two year old one you are recommending.
Old Jun 4, 2008 | 06:33 AM
07rdsterGT's Avatar
07rdsterGT
Glad it could help buddy
Old Feb 19, 2009 | 11:14 PM
gennosuke1's Avatar
gennosuke1
nice write up, its relief that you dont have to take the front bumper off. would you be able to tell me where to exqactly screw off, maybe pics would be helpful VERY
thanks
Old Feb 20, 2009 | 07:12 AM
  #38
reserved's Avatar
reserved
me too
Old Feb 20, 2009 | 08:05 AM
  #39
07rdsterGT's Avatar
07rdsterGT
When you peek up at the corners inside the bumper you will see two screws. No need for pics. Its right there in ur face.
Old Feb 20, 2009 | 09:10 AM
  #40
samjcg's Avatar
samjcg
guys. chill out.
The more help from the community, the better is it for us.
There is no BEST way to install Clear corners... now we are open to 2 options. It is always better than 1.
