cant figure out auto window after fixing the motor!!
Old Jun 23, 2008 | 04:18 PM
dere321's Avatar
dere321
Default cant figure out auto window after fixing the motor!!
well guys i just fixed the window motor in my 03 350z and i cant figure out how to reprogram it ...
well i programmed it to roll down a bit when you open the door but this is where i get lost ...
well it does the anti pinch but then when you go to close the door the window just rolls down half way ....
also i cant get the auto up and auto down to work .... please help me out ...
-derek
Old Jun 23, 2008 | 08:21 PM
gregom's Avatar
gregom
I didn't know that could be changed... I hope you find an answer because i'm interested.
Old Jun 23, 2008 | 09:56 PM
z2g's Avatar
z2g
Sounds like what happened to my car(hope its not) b/c it ended up being my BCM becoming faulty
Old Jun 24, 2008 | 08:09 AM
VO...'s Avatar
VO...
Administrator
See my Stickied How-To thread in the maintenance section. It has the reset procedure inside....
Old Jun 24, 2008 | 11:28 AM
str8dum1's Avatar
str8dum1
did you do the motor reset?
if you search those terms theres a clear how to with pics. just did mine the other day. took 10 mins
basically u r pushing the motor reset button and rolling the window down. then release the reset button and roll the window up. doing that with the door closed and not using auto up or down.
Old Jun 24, 2008 | 07:54 PM
yusoslo's Avatar
yusoslo
try the motor reset....but I just unplugged the battery for a day and it worked
Uriyo_
Sep 8, 2021 08:46 AM
_bit
Oct 2, 2015 07:49 AM
Depravity
Oct 1, 2015 04:49 PM
