Front cubby door removal?
Old Jul 20, 2008 | 01:57 PM
gambino's Avatar
gambino
Default Front cubby door removal?
Hey guys, I did some searching and didnt find my answer. Doesnt mean the answer isnt out there, and if I missed it, I apologize. But is it possible to just remove the door for the front cubby above the radio?
Old Jul 20, 2008 | 01:59 PM
lbz's Avatar
lbz
I've not tried that but I assume you would have to remove the center console in order to do it. Should be plenty of DIY guides on the forum for that.
Old Jul 20, 2008 | 07:58 PM
gambino's Avatar
gambino
I browsed that section for a bit and couldnt find anything.
Old Jul 20, 2008 | 09:18 PM
SlideWays314's Avatar
SlideWays314
i would not advise it. it is impossible to get it to go back on and function the way it did before you take it off. I have a cubby out of an '06 with the door already removed if you need it. I had to end up buying a new one because I took off the door.
Old Jul 20, 2008 | 11:49 PM
quakerroatmeal's Avatar
quakerroatmeal
Is it that serious? Why is it impossible to put back and function the way it did before?
Old Jul 21, 2008 | 01:07 PM
gambino's Avatar
gambino
Well I mostly want the door off because I am going to build an ipod/ems control unit holder to fit in there.....so it is mostly just experimental to see if I want to modify the door or build a whole new unit to go in there.
Old Jul 21, 2008 | 02:31 PM
SlideWays314
like i said, i got one with the door already off for sale.
Obadabot
Jun 18, 2023 11:31 PM
07ZEKE
Aug 23, 2021 09:15 PM
sales@czp
Sep 23, 2019 03:30 PM
