Lexan/CF HATCH EXPERT NEEDED!
Old Dec 17, 2008 | 05:53 PM
  #41
INTIMAZY's Avatar
INTIMAZY
Originally Posted by ohSIXz
im all about weight savings, but im also all about TINT!
Just get smoked lexan. Its almost as dark as a 5% tint.
Old Dec 18, 2008 | 02:26 AM
  #42
Germanguy's Avatar
Germanguy
Originally Posted by Germanguy
need help, because I have to order the rear lexan from a german producer, who never made it for a Z before.
How much bolts are in the lexan? I think 24?
How long/wide are they, and from which type are they?
Are they steel?
Need help!
Thanks
help
Old Dec 18, 2008 | 07:39 AM
  #43
guitman32's Avatar
guitman32
i always thought the FRONT of the Z was heavier than the rear, wouldnt that make a CF hood better for weight savings/distribution and overall balance of the car?
I notice a BIG difference in the handling dynamics with just and empty vs full tank. Let alone an empty tank with the spare and tools removed. Whenever I autocross, the tank is 3/4 or more full. The tail is a little too happy for me with everything removed.
I can only imagine how "happy" things could get with less than 3/4 tank, no spare/tools, and a CF hatch/lexan.
Although, I do think the weight savings of a CF hood are proportionally minor compared to a CF hatch/lexan.
Old Dec 18, 2008 | 07:44 AM
  #44
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
that's why you get a car cornerbalanced ^
Old Dec 18, 2008 | 05:37 PM
  #45
INTIMAZY's Avatar
INTIMAZY
Do you know any places that would cornerbalance/do an alignment and possibly even set up coilovers in the NYC/Long Island area? The japanese instructions included with my Cusco Zero2 are difficult to understand and I don't know the proper range for how far the shock body and preload should be set to.
Old Dec 21, 2008 | 10:09 AM
  #46
Kwame's Avatar
Kwame
I believe Nissan Motorsport also offers a Lexan rear hatch window for the 350z.
Old Dec 21, 2008 | 10:36 AM
  #47
Archaismic's Avatar
Archaismic
EDIT: Before reading on Muzzy... i still love your car and you rock a z like most can only dream
Originally Posted by MUZZY
wrong!
stock glass 35lb
lexan 1.5 lb
stock hatch with glass 180 lb
CF seibon hatch stripped with 1/8 lexan 22.5 lb
ou save 157.5 lb thats 1 extra person, you can tell the difference im telling you
i guess since you're so eloquent i'll honor you with mimicry
WRONG!
though... to get full effect caps are required... maybe a picture too but im lazy
stock glass weighs about 5 lbs(if that)... just finished transferring mine over to a MG CF hatch...
and the stock hatch with glass (pulls out scale... brb...)
weighs just over 55lbs...
Disclaimer... this is on an 03 track so some weights may be a little off...
don't be mean AND stupid... pick one
if you want to look at some pretty good weight reduction stuff go here
http://*********.com/zwiki/Weight_Reduction_Guide
Last edited by Archaismic; Dec 21, 2008 at 10:41 AM. Reason: keep from making muzzy too mad
Old Dec 21, 2008 | 10:46 AM
  #48
Archaismic's Avatar
Archaismic
ohh and just to add to the original question... if it hasn't already been beaten into da heads of all... yes drilling lexan is a pain in the *** and it cracks easy, no you don't need a special mounting kit... to help with the cracking use a lightweight cutting fluid (or WD-40 or something) and if you're really scared use a grinder bit instead of a drill bit... like with a dremel... sorry for all the "..." i can't help it... and as a general note with swapping hatches and glass the gooey rubbery sealant stuf around the mounting screws for the hinges will not hold up by itself... it tends to leak if you don't reapply it (is dumb and found out by having a grounded rear stoppy light in the middle thingy
Old Dec 21, 2008 | 02:05 PM
  #49
Jim@Showstoppers's Avatar
Jim@Showstoppers
WRONG!
blah blah blah ... .... ...
I'm going to go with Muzzy on this. The stock glass does not weigh 5lbs it's considerably more. It's a pretty well known fact that lexan windows are a CONSIDERABLE weight loss and I believe Muzzy's weights are actual...meaning he weighed everything when he did his install.
I'm sorry dude, but I've read most of your posts and you give out alot of false and inaccuarate information.
Old Dec 21, 2008 | 02:09 PM
  #50
Jim@Showstoppers
good to know, I've had a ton of people asking.
Old Dec 21, 2008 | 05:43 PM
  #51
Archaismic's Avatar
Archaismic
Unhappy
I never said it wasn't a considerable weight loss... 5 lbs is a pretty decent loss for something that can actually be replaced on the car not just removed, but really, i can pick up the stock glass between my thumb and forefinger with it covered in WD-40 and slippery, and my 115lb wife can lift the stock hatch by herself and move it around the back yard (as she keeps doing to get it out of her way) it does not weight anything close to 150lbs, or even 100 for that matter... both the weights he has put out there are completely wrong, when I'm not snowed in I'll go get batteries for my camera and show you all pictures of at least the hatch on a damned scale or something.
Originally Posted by Jim@Showstoppers
I'm sorry dude, but I've read most of your posts and you give out a lot of false and inaccurate information.
the ONE post i made that was wrong (about pricing) was way off because I hadn't checked the prices in a few months and i immediately recanted, said I was wrong and posted a link to proof that i was wrong, one out of what 39. I challenge you to actually read a few of my posts and find something other than that ONE post. And let me know so I can fix it.
Old Dec 22, 2008 | 03:53 AM
  #52
MUZZY's Avatar
MUZZY
lets all be grown ups here. Im here to help. sorry if I sounded mean with previous post. Im just trying to help my fellow Z buddies
Old Dec 22, 2008 | 06:43 AM
  #53
Jim@Showstoppers
Show me a picture of the glass on the scale where it weighs 5lbs.
Old Dec 22, 2008 | 06:45 AM
  #54
Archaismic's Avatar
Archaismic
well im not going to pull the glass out of my hatch again, but i'll go get a shipping weight from nissan when the roads clear up
  #55
Jim@Showstoppers
Muzzy said the glass weighed 35lbs, not 150 or 100lbs. Your claiming the stock glass weighs 5lbs. Calm down and read the posts.
stock glass 35lb
lexan 1.5 lb
WRONG !
Old Dec 22, 2008 | 11:30 AM
  #56
Archaismic's Avatar
Archaismic
yeah?... he said the hatch weight with glass was 180lbs... minus the 35 is... 145... i just rounded to 150. those numbers were talking about the hatch without glass cause that's what i have sitting in my back yard, the glass weighs about 5 lbs which i reinstalled in the hatch. i'm going to go get weights from nissan when the roads clear up and we can stop arguing. all i'm really trying to say is that switching to CF hatch with lexan doesn't save 115 lbs or so... it's about 45 lbs difference, just like the post from 350ztech i linked up estimates. i hate arguing, i just thought it was worth pointing out the 60-70 lb difference between the posted weight loss and the actual weight loss. when it comes to racing that's a HUGE difference. If you could actually lose 115 lbs for only about $1200 that's like gold. It just seemed a little off to make the claim. Like i said originally also, my weights are for an 03 track. The difference might be that, but I doubt it.
Old Feb 10, 2009 | 10:30 PM
  #57
Archaismic's Avatar
Archaismic
stock hatch=47lbs... so i was wrong but right check this https://my350z.com/forum/members/arc...s-weights.html .. the picture with the weight is in the gallery there
Old Feb 17, 2009 | 06:33 AM
  #58
zman600's Avatar
zman600
.........anyways
i love the look of the bolts/rivs. make people think twice when pulling up next to u @ the light cus of how "professional" or "beast from the track" it looks.
cant wait for when i do it but rims/coilovers r next 4 me.
Old Mar 1, 2009 | 07:55 AM
  #59
whitelightnin's Avatar
whitelightnin
Whoops..
Old Mar 1, 2009 | 08:04 AM
  #60
j.arnaldo's Avatar
j.arnaldo
Where are you from, INTIMAZY; you wrote moulding instead of molding. Greetings from Puerto Rico, U.S.A.!
