veilside vi1 front lip
Old Aug 21, 2008 | 10:25 PM
nick123's Avatar
nick123
Default veilside vi1 front lip
Alright, so i purchased an origional veilside front lip after my INGS disaster with the front lip REPLICA...The fit is much better...The sides and everything seem to go on like a glove...NOW, the middle portion where thecenter of the lip sits ontop of the bumper, mine seems a bit short and is showing the bumper at the top....can people post pics of the veilside v1 front lip on their car..
Old Aug 21, 2008 | 10:59 PM
Bumble_Zee's Avatar
Bumble_Zee
FREEDOM FIGHTER
mine took alot of grinding to make it fit. Well, it came with the car when I purchased it for free, but WTF!!! it's a Veilside and it's a fawkin' tight fit???!!!
Old Aug 21, 2008 | 11:13 PM
DaeHan's Avatar
DaeHan
nice rims bumble zee
Old Aug 24, 2008 | 02:12 PM
iNi_REALiZED's Avatar
iNi_REALiZED
When you guys mount your lips, are you just using double sides tape in the middle, and using the two oem bolts on each side underneath the lip?
Old Aug 25, 2008 | 08:09 AM
VeilSideBrian's Avatar
VeilSideBrian
PM replied.
also, with the lips (and any products really) the gel coat on top is simply not going to cure in the EXACT same way everytime. Sometimes it is a bit thicker than usual, and that is just due to it's nature.
It is better for the part to be a bit tight rather than a bit loose. If it is tight, you can simply sand some small areas, but if it is loose, you would have to ADD material to make it fit.
I hope this helps.
Old Aug 25, 2008 | 08:56 AM
Z04's Avatar
Z04
that is all i did for mine
Old Aug 25, 2008 | 03:04 PM
VO...'s Avatar
VO...
Administrator
You can find lots of close-up pics of mine, here:
https://my350z.com/forum/media-share...-veilside.html
Obadabot
Jun 18, 2023 11:31 PM
Dymsi
Sep 29, 2015 11:32 AM
