type of flasher unit in 07 Z?
Old Aug 22, 2008 | 06:42 PM
contraststriker's Avatar
contraststriker
Default type of flasher unit in 07 Z?
All,
I'm wiring up some LEDs for my front sidemarkers and getting them to blink like a normal turn signal requires modification of the flasher unit...does an 07 Z use electronic or thermal flashers? I found a procedure for modifying the flasher, but it only works on electronic flashers.
Help is much appreciated!
Old Aug 23, 2008 | 06:29 AM
sintaxeror's Avatar
sintaxeror
...........Why does this need mods to the flasher unit?
Old Aug 23, 2008 | 07:38 AM
z350boy's Avatar
z350boy
There is a thread somewhere on the site that talks about having to use resistors to control the flash. I'd search it for you but the search can be time consuming.
Old Aug 23, 2008 | 12:48 PM
contraststriker
yes using load resistors to simulate an incandescent bulb works but modifying the flasher unit also works. The problem with LEDs is they draw less current than an incandescent bulb, thus the flasher thinks there is a bulb out and doubles the flash rate.
lapham3
Oct 7, 2022 03:15 PM
May 30, 2017 03:28 PM
dcains
South East
20
Feb 22, 2016 10:27 PM
dcains
Nov 11, 2015 11:36 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
