where to get chrome turn signal bulbs?(7440)
SOunddomain.com is sold out of the chrome turn signal bulbs from APC that blink amber....anywhere else to get these?any stores that may have them?
Try Claude (Oppaman Z) in Canada. I know he offers the Philips bulbs for the Z32 clear corners. oppamanz@sympatico.ca
This guy is legit, they're actually lightly chrome plated there's a lot of silver painted ones out there that are junk.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2426235823
I have a set on my car they were a bit difficult to put in the socket I had to file down the plastic on the bulbs input end to get it to fit into our sockets for some reason.
I also purchased a set for the rear that I am not using yet because they do light up Amber but not quite as bright and I would prefer to have my rear turn singles very visible. I figured I will just save the other set for spares
so these bulbs in the auction link u posted are chrome plated and good, but are they not as bright when they light up as the stock front turn signal lights?if they are almost the same ill buuy em...
They are the best that I have found , the very thin chrome plating does take away from some of the brightness 25% and they are amber when they do light up for the front their fine.
They look a lot better than stock because the amber stock ones reflect all over the whole light practically when not lit yak.
If you do get them be careful when removing and replacing them which is a bit tricky if you drop one into the housing I'm not sure how you would get it out it would be bouncing around in your whole headlight assembly. I imagine a piece of bubblegum on a stick might do
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
