finally found the lowest seat?
Old Aug 25, 2008 | 02:31 AM
350Z_GTS's Avatar
350Z_GTS
Talking finally found the lowest seat?
I have used the search button like no other the past week lol. I have finally gathered what i think is enough info on what is the best seat for a a tall person like myself. I noticed z1 performance said the bride base was lower than the recaro so i was thinking recaro speed with recaro rails and a bride base. Im 6' 7" with about 36 waist and looking to sit lower. Any advice would be great. That and Im sure it would answer any future questions becaue i have looked and there is still no one answer for what is the lowest seat possibility for us tall people. I saw a pic of a member (cant remember who, white z with recaro speed/ speed s) and it looked like it was on the floor. Seat like recaro has to feel good and if it sits that low i want it. Any advice would be great.
Old Aug 25, 2008 | 04:08 AM
Kwame's Avatar
Kwame
I got your PM but from the post above you seem to have already found the answer. The only thing is I not running Recaro rails. I'm running the Recaro Speed seats with Bride bases.
In any case I'm only 6' tall and my waist size is 34/36. Your a lot taller than me so I'm not sure how you will fit with the same setup.
Old Aug 25, 2008 | 04:12 PM
MaRbLe's Avatar
MaRbLe
I have Gias's with the Bride bases and they a pretty damn low...
Old Aug 25, 2008 | 04:19 PM
turismo's Avatar
turismo
Hey, sorry to get off topic but.....Kwame, we talked about the Corbeau's, whats the lowest setup I should go with. I'm 6'4. Could you put together another price sheet for me with that setup
Old Aug 26, 2008 | 01:19 AM
350Z_GTS's Avatar
350Z_GTS
so since you dont have any rails, the seat cant move i assume. Can it be positioned back or further forward or do you have to drill holes to make it work with just using the base?
Old Aug 26, 2008 | 06:00 PM
andrew16639's Avatar
andrew16639
Do you have the low cushion or the standered one
Old Aug 26, 2008 | 08:36 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
Recaro SRD would actually be better for you than the speed...less bolster
Old Aug 27, 2008 | 01:18 AM
350Z_GTS's Avatar
350Z_GTS
its not that, if anything the speed s, the bolster is a little tight, slightly uncomfortable but i think thats just cause im not use to it. No, i just wanted to know if the seats from kwame sat as far back as possible of if i would need rails to make the seats go further back. Also Kwame, what bride frame is it, the mo?
Old Aug 27, 2008 | 07:00 AM
Kwame's Avatar
Kwame
Chris, truthfully I really can't answer that question. Simply because you can't mount a seat without a base and not all bases are compatible with all seats.
Old Aug 27, 2008 | 07:08 AM
Kwame's Avatar
Kwame
What you are referring to as "rails" are the same thing as what I am referring to as "bases." Bride bases include sliders which allow you to move the seat forward and backwards.
No extra drilling is required to use the bride bases with the Recaro Speeds. The bases screw into the pre-drilled holes in the bottom of the seat with the supplied hardware.
Old Aug 27, 2008 | 07:25 AM
VO...'s Avatar
VO...
Administrator
My Vorgas with Bride rails are pretty low. Stock height thigh bolsters also. Gives me room to let t3h nutz hang...
Old Aug 28, 2008 | 12:02 PM
MaRbLe's Avatar
MaRbLe
Standard...
Old Sep 6, 2008 | 07:26 PM
Eric the Ricer's Avatar
Eric the Ricer
I want a low seat also, I have a long waist, so I need some more headroom. I'm 6'6" 240, with a 38 waist right now, I'll be down to a 34-36 in a month or two (hopefully). I've wanted a new seat for a while now, what would my best option be?
Old Sep 6, 2008 | 08:18 PM
got556's Avatar
got556
Memory Fab's w/ the low/max sliders (if you want sliders) are pretty low from what I hear.
Old Oct 20, 2008 | 07:08 PM
godbecks's Avatar
godbecks
u guys can try to mod ur necks
Old Oct 21, 2008 | 09:20 AM
Citrus's Avatar
Citrus
Nagisa Auto Super low rails here, my Buddy Club seat is literally a millimeter off the floor. My 5'3 wife can't see over the steering wheel without a phone book.
Old Oct 21, 2008 | 09:26 AM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
what do those look like? pics?
Old Oct 21, 2008 | 09:35 AM
Kwame's Avatar
Kwame
Unfortunately, the only fit bucket seats. Most people go with reclining seats due to the added comfort, unless its for a track car.
Old Oct 21, 2008 | 12:53 PM
seekndestroy19's Avatar
seekndestroy19
when i had my sparco base in it was alot lower than stock in my 03. Now i have bride seats with bride base and they sit higher than stock for some reason
Old Nov 15, 2008 | 05:54 AM
rfm's Avatar
rfm
I'm also looking to buy a 350Z, but with just 1 cm of headroom left I'm also interested in lower rails.
Are there any low rails out there that fit the standard seats ?
Did anyone try to modify the standard rails ? I think it would be possible to cut a few centimeters out of the legs. And is the floor of the 350z underneath the seat flat ?
