help please
Old Sep 3, 2008 | 08:55 PM
redsoxfan184524's Avatar
redsoxfan184524
Nts Nts Nts Nts
Default help please
ever since i crashed my car, the ajar door light stays on but the doors are closed all the way, and the lights by my feet stay on all the time. should i just take the fuse out what can i do about it? its pissing me off
and if i take the fuse out, i still want to have my gauges lit up and have the dome light
Old Sep 3, 2008 | 08:59 PM
Sean's Avatar
Sean
it's the mirco switch, it must not be making contact with the door....you need to find it and adjust it back to normal or cut the wires and possibly splice them together if just cutting one isn't enough.
Old Sep 3, 2008 | 09:04 PM
coreapoc's Avatar
coreapoc
If the only issue is the light, and its not cosmetically damaged just pop off the panels and readjust the sensor. Unfortunately with these ******* things if its off by even half a millimeter it wont register.
If that doesnt work, do what he said. Splice the wires together. Problem solved.
Old Sep 3, 2008 | 09:09 PM
redsoxfan184524
Nts Nts Nts Nts
its a 3000GT, and the car is messed up, but drivable. there are pics in the media section under 'my new car' thread
Old Sep 3, 2008 | 09:12 PM
Sean's Avatar
Sean
somewhere in your door frame is a small area you can push to make the ligh go out, usually a metal stub or post that compresses.... find it. Typically it is in the front of the frame, half way up.
It would have to be somewhere that the door would normaly hit it when closed only.
Old Sep 3, 2008 | 09:18 PM
Sean's Avatar
Sean
here is an example, you will only see the end of it, it may be fully covered by a black rubber bubble to prevent corrosion
http://www.ecklers.com/product.asp?p...5&dept_id=1666
Old Sep 3, 2008 | 09:22 PM
redsoxfan184524
Nts Nts Nts Nts
i'll check for it tomorrow. there are a bunch of wires coming from the door, and a lever off of it, but i push the lever and the wires come out, so im guessing thats not it, and the lever is just a lock for the box the wires are in?
Old Sep 4, 2008 | 04:58 AM
phreaktor's Avatar
phreaktor
Design Engineer
Old Sep 4, 2008 | 06:05 AM
redsoxfan184524
Nts Nts Nts Nts
thanks phreak. never posted in the tech forums.
im gonna check it out today and i'll st some pics of what it all looks like and maybe someone can help me.
Old Sep 4, 2008 | 12:25 PM
redsoxfan184524
Nts Nts Nts Nts
so the fuse that shuts off the floor lights are connected to the radio...grr. so i have to drive with the floor lights on to listen to the radio, and take out the fuse every time i get out
Old Sep 4, 2008 | 12:55 PM
Z04's Avatar
Z04
he meant wrong froum, as in this is not a 3000GT forum
Old Sep 4, 2008 | 01:29 PM
redsoxfan184524
Nts Nts Nts Nts
touche.
figure there would be people here that could help me tho
Old Sep 4, 2008 | 01:33 PM
Sean's Avatar
Sean
make with the pics.
Old Sep 4, 2008 | 01:46 PM
redsoxfan184524
Nts Nts Nts Nts
i went feeling around in there, and found nothing. i think its connected through the door jam..couldnt find a button in there. i might take it to a shop to see if they can figure it out, but i dont really want to spend money on this car now that i crashed it. had some plans to fix it up before i crashed it too
Old Sep 4, 2008 | 02:16 PM
redsoxfan184524
Nts Nts Nts Nts
figured it out...im such a retard. i was trying to feel/look in the door jam where the door and the front fender connect, but the button was right near the lower part of the door, so i just taped it down for the night, and i'll put something on the door that hits it when i close the door.
when i hit the guard rail, it bent my door out a little so it wasnt being hit
thanks sean for helping me out
