Quick headlight question
Old Sep 4, 2008 | 10:58 AM
drewb612's Avatar
drewb612
Default Quick headlight question
Will an 07-08 headlight work plug and play on an 03? If I were to buy just the headlight housing with no bulbs/ballasts or anything else, can I swap the stuff from my 03? Thanks!
Also I know the pictures arent great but does this look alright for an 07 housing?
Old Sep 4, 2008 | 11:21 AM
nothix's Avatar
nothix
no
Old Sep 4, 2008 | 11:23 AM
drewb612's Avatar
drewb612
Originally Posted by nothix
no
ok...what aspects are not compatible? Is it something that can be easily modified to make it work?
Old Sep 4, 2008 | 11:37 AM
Z04's Avatar
Z04
first off, they are not even the same type of lights. the 03-05 lights are a single HID for lowbeam only, where the 06+ are a bi-xenon (both high and low beam).
Old Sep 4, 2008 | 02:32 PM
Yellow Stealth's Avatar
Yellow Stealth
Boy, this crowd is tough...
Drewb, if you buy the full 07-08 headlights (with bulbs/ballasts), then yes, they are plug and play, although the new turn signal bulbs will stay on all the time when the car is on. It is not a big problem (they end up sorta working like daytime running lamps) but if you don't like that, you can cut one of the wires on the turn signal bulb. That is what I did and they now operate just as turn signals.
Someone posted a diagram a long time back on which wires to cut, so do a search and you should find it. Hope this helps.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
