350z roll cage
Old Sep 6, 2008 | 06:08 PM
aalzuhair's Avatar
aalzuhair
Default 350z roll cage
I'm looking for a roll cage that should connect the chassis from the front shock towers to the rear shock towers (10 or more points). Noting that none of the interior stuff will be retained including dash
If anybody knows someone that could do that or already have done that please let me know as I have looked high and low for anything that is even close to that but to no avail.
Thanks,
Az
PS: If any of shops out there is willing to work on something like that please PM me or post.
Old Nov 5, 2010 | 08:13 AM
slmdchvy05's Avatar
slmdchvy05
I would be interested in that as well in the future... If you hear of something let me know
Old Nov 5, 2010 | 08:19 AM
aalzuhair's Avatar
aalzuhair
RJN Motorsports in the UK
Here is a link for my car
http://www.ls1tech.com/forums/conver...assis-ls2.html
Old Nov 5, 2010 | 08:33 AM
mw9's Avatar
mw9
thanks for the pics, good luck with the car.
Old Nov 5, 2010 | 08:55 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Holy chit that's one hellova roll cage!
Old Nov 5, 2010 | 09:09 AM
GreenGoblin's Avatar
GreenGoblin
Looks sick any more info on converting the ps to a manual rack?
Old Nov 5, 2010 | 09:23 AM
aalzuhair's Avatar
aalzuhair
Basically what you would need to do is open the rack from the passenger side after discounting the rods, and then you would need to take out the piston (this part is bolted on the rack on the inside).
Next you would need to open the servo housing and taking out all of the O rings and plunging all of the 4 ports. You need to also weld the two inlets on the housing
After that you need to clean everything up and grease it up and bolt it back on.
Az
Old Nov 6, 2010 | 11:19 AM
bgood's Avatar
bgood
Az
good luck. i had 275's up front with power steering and i needed allot of arm strength to keep it pointed in a forward direction.
Old Nov 10, 2010 | 02:06 PM
World Famous Z's Avatar
World Famous Z
aalzuhair, are there no shops or fabricators in Saudi there by you that can do it?
BTW my cousin used to live in Riyadh, and some of my family lives out there!
Old Nov 10, 2010 | 04:51 PM
terrasmak's Avatar
Thats odd, not really the strongest person in the world (6'1 170) but i don't have that problem with my 275's up front. Now it is a lot better with the compression arm bushings changed to not blown ones.
Old Nov 10, 2010 | 10:25 PM
aalzuhair's Avatar
aalzuhair
Back then, we did not have anyone which can issue an FIA certification.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
