Front reflectors
Old Oct 6, 2008 | 02:46 PM
Zultimate's Avatar
Zultimate
Default Front reflectors
Finally got my new clear reflectors ordered. For those of you that have changed these, what is involved? Do the wheels need to come off? Need to be on a lift? Panels removed?
Old Oct 6, 2008 | 03:21 PM
PerfZ's Avatar
PerfZ
Need to remove the front bumper bolts under the hood, under the caps. Remove the wheel well liner bolts at the bottom where they bolt into the bumper and pull the liner out a bit. Reach in and unbolt the headlight support brackets, think there are two bolts in there. Then you can reach the reflector mounting bolts. You do NOT need to remove the bumper, nor the wheels. Not really all that difficult - took 2 of us 30 minutes to do mine. There is probably a better step-by-step somewhere on this forum, or for sure on at least one of the others.
Old Oct 6, 2008 | 03:38 PM
Spork's Avatar
Spork
You can install it by going through the wheel liners.
You can also remove the front bumper to take this time to clean anything out.
Old Oct 6, 2008 | 04:48 PM
shawn_david75's Avatar
shawn_david75
The one on the right side is a b**** if you do it with the bumper on, because the windshield washer reservoir is right up against the reflector bolts.
Old Oct 6, 2008 | 05:36 PM
06-ZBOY's Avatar
06-ZBOY
where can i purchase clear reflectors?
your guys help would be greatly appreciated
Old Oct 7, 2008 | 09:28 AM
trodis's Avatar
trodis
+1, I dont know how people go around that thing??
I had to remove the front bumper. If you can find someone that has done it before (bumper removal), I highly suggest having them do it. It takes about 20-30 min installed, if you know what you are doing/looking for.
Old Oct 7, 2008 | 09:29 AM
trodis's Avatar
trodis
got mine from MyNismo.com I think...
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
