Disable airbag lights? new seats and steering wheel
Old Oct 7, 2008 | 01:01 PM
350zzzgunnar's Avatar
350zzzgunnar
Question Disable airbag lights? new seats and steering wheel
Gona fit quick release kit and Bride seats.
Can I disable the lamp itself easy, it's a LED, right?
Or do I have to fit resistors? 2.2ohms for front airbags and 2.7ohms for side ones?
Old Oct 7, 2008 | 04:49 PM
SchismX's Avatar
SchismX
Resistors will be fine.
Old Oct 7, 2008 | 10:23 PM
350zzzgunnar
^thanx
anyone knows anything if/how about attacking the lamp itself?
Old Oct 8, 2008 | 03:55 AM
imonlykidden's Avatar
imonlykidden
my damn resistors did not work. Air bag light on FTL!
Old Oct 16, 2008 | 10:57 AM
enuff4life's Avatar
enuff4life
same problem... where can i get the airbag light resister?
Old Oct 16, 2008 | 01:18 PM
Chebosto's Avatar
Chebosto
steering wheel airbag on USDM cars takes TWO resistors.
seat only takes on on 03-05.5.. i think the 06-08 Z have weight sensors in which you will have to roll up to fool that there is > than 75 or 80 pounds of weight( or something like that)
there are airbag reset procedures that i posted up a while back (do search for SRS Airbag) that should reset your flashing airbag light..
you must have turned on the car w/o the resistor in place.. that will make it flash..
Old Oct 17, 2008 | 04:42 AM
350zzzgunnar
gave up finding a resistor in this f***ing country, so I'm leting John disable the light when he's doing my LED conversion. Until then it will flash
Old Oct 20, 2008 | 11:50 AM
Chebosto's Avatar
Chebosto
do u have an electronics store in sweden? place that sells build your own radios, etc.
you can make the resisor plug in so easy.. less than $2US
Old Oct 22, 2008 | 12:41 PM
350zzzgunnar
Thanx for replying
No I didn't find anyone, even though it must be more than one, there's no one close enough. And I'm in a big hurry since I'm repainting the car and doing lots of work to make it fit for a major car show.
I'll let the lamp flash until disable it at the led conversion
Old Oct 22, 2008 | 02:45 PM
CaneZMD's Avatar
CaneZMD
So is there a thread that says how to disable the light for the passenger bag using the resistors?
Old Oct 22, 2008 | 04:22 PM
Chebosto's Avatar
Chebosto
passenger airbag.. in the dash? or in the seat?
Old Oct 23, 2008 | 06:13 AM
CaneZMD's Avatar
CaneZMD
My airbag light turned on. I tried the reset procedure, but it just stays on. the code that it flashes is for the passenger dash air bag.
I'm the only one that ever rides in the car, so I'm not concerned with it being operational....and a new passenger dash back is about $1K dollars.
So how and where do I place a resistor to get this thing turned off?
Thanks so much.
Old Oct 31, 2008 | 04:46 PM
mason's Avatar
mason
the dealer says that both of my seat airbag sensors are bad and it will be about $1000 to fix...i have heard of making your own reisistors to disable the airbags and make the airbag light go away, does anyone have a good picture of a resistor installed, i am going to pick up some cheap resistors from radioshack and attempt to make and install them myself, thanks
Old Nov 13, 2008 | 05:08 PM
mason's Avatar
mason
i tried everything (sticking the resistors into the holes, used wire splicers to connect them, and directly connected them with a jump cable) with 5, 1/2 watt 10ohm resistors in parellel, and nothing works. both of my seat airbag sensors are bad and im trying to get rid of the airbag light so that i will at least have front airbags. does anyone have any suggestions as of why its not working, and what to do differently? thanks
Old Nov 14, 2008 | 10:28 AM
kihun's Avatar
kihun
somebody post up damn picture of resister so i can make one!!!
Old Nov 24, 2008 | 12:10 AM
ekidd's Avatar
ekidd
+1 ....and why did the resistor that came with my momo hub look like a fuse?
Old Nov 24, 2008 | 08:41 PM
kihun's Avatar
kihun
bump.. please picture anybody.
Old May 30, 2009 | 04:28 PM
Rushhour's Avatar
Rushhour
my resistor looks like a fuse too. I also received one resistor i don't know what that is all about. Let me know how you fixed your airbag light problem. I'm in need of help.
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
Depravity
Oct 1, 2015 04:49 PM
