How do I remove my stock XM antenna?
Old Oct 26, 2008 | 10:47 PM
calin's Avatar
calin
Question How do I remove my stock XM antenna?
So I'm thinking about getting a black vinyl overlay for my roof and don't know what to do with the stupid XM antenna on my roof . Does anyone know how it's attached to the roof? Is it screwed on from the inside? double sided tape? I'm not sure how to go about taking it off. I want to see how big of a hole there is underneath it. If it's just a small hole, I'll leave the antenna off and just cover it with the vinyl piece. But if the hole is big, then I'm pretty sure you'll be able to tell there's a hole in the roof after putting the vinyl on and that would look bad .
So does anyone know how to take this sucker off?
Old Oct 27, 2008 | 06:07 AM
calin's Avatar
calin
bump....nobody?
Old Oct 30, 2008 | 10:00 PM
stikerbanana's Avatar
stikerbanana
bump...
Old Oct 30, 2008 | 10:50 PM
calin's Avatar
calin
Old Oct 31, 2008 | 07:46 AM
Done Deal DR's Avatar
Done Deal DR
Dude..I may be wrong here...but I don't think that is factory.
the fact that I don't see a cord going to the hatch area tells me there is a good chance they drilled through your roof. Generally speaking, those antenna's are either held on by a magnet or double sided tape. I'm assuming you would have already realized if it was a magnet as you could just walk up and take it off, but double sided tape can be REALLY strong. Try some fishing line or something similar and see what happens if you try to "floss" under it. if it doesn't budge at all, it MAY be screwed/bolted to your roof, though I've never personally seen that done. I'd be more worried about a hole in your roof if they did in fact drill through your roof. Mastergrade roof cap? LOL
Best of luck man.
Old Oct 31, 2008 | 08:03 AM
WhiskeyHotel's Avatar
WhiskeyHotel
Nope - it is factory and yes, they did drill through the roof. It is probably held on with tape and likely other fasteners. Hop over to Courtesy Nissan parts web site and look up the XM antenna - I imagine it'll clear up how it's secured, etc.
Old Oct 31, 2008 | 08:10 AM
Done Deal DR
^Good call.
I don't recall ever seeing that before now.
Old Oct 31, 2008 | 08:18 AM
calin's Avatar
calin
Sweet, I'll check that out thanks. I took a close look at it last night and I don't think it's held down with double sided tape now. There's a very thin piece of rubber between the antenna and the roof (I'm guessing to prevent scratching), but I think it might be screwed on from the inside of the car. Guess I can't do my roof overlay now since there's most likely a hole in the roof
Old Oct 31, 2008 | 08:19 AM
calin's Avatar
calin
It is factory because I bought the car brand new and it came with that stupid antenna
Old Oct 31, 2008 | 08:53 AM
Done Deal DR
I would at least try to take it off. I'd be willing to bet that the hole isn't extremely large...you probably couldn't get away with a vinyl roof overlay, but you could easily get away with a roof cap, a la Mastergrade.
Old Oct 31, 2008 | 08:56 AM
calin's Avatar
calin
I'd actually prefer a vinyl overlay over carbon fiber. I already have a cf lip and sides so I don't want to go overboard
Old Oct 31, 2008 | 09:05 AM
Done Deal DR
Paint it black... ...you've pretty much cornered yourself into a wall with your options. Your only other option would be to go to a body shop and have them fix the hole and paint it, or then apply the vinyl, though if you're already at the body shop might as well just have them paint it.
Best of luck man!
Old Oct 8, 2009 | 11:36 AM
350Speed's Avatar
350Speed
calin,
I'm in the same situation here, so please let me know what you did with the antenna.
Thanks.
Old Oct 8, 2009 | 12:37 PM
calin's Avatar
calin
Originally Posted by 350Speed
calin,
Thanks.
I left it on since there will be a huge hole in my roof if I remove it
Old Sep 25, 2010 | 10:28 AM
candyandy's Avatar
candyandy
i think im gonna remove this piece and get the it wrapped as well. how did you go about removing it? anyone please chime in.
sales@czp
Sep 23, 2019 03:30 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Depravity
Oct 1, 2015 04:49 PM
