Headlight HAZE with Pics !!!!
Old Nov 7, 2008 | 12:05 PM
sam2944's Avatar
sam2944
Looks like it is inside humidity. But if you are 100% the matter is outside you should use Meguiars Plastic Cleaner before any sanding. If the damage is too big you may then sandpaper with much dishwasher, use 2000 grit. Then polish with the Meguiars and at least weekly apply wax to avoid return of debris and protect against solar UV rays. I do it almost daily with our customers locally. Good luck! WWW.SAGAHID.COM
Old Nov 7, 2008 | 12:34 PM
ParanoidAndroid's Avatar
ParanoidAndroid
At the body shop I work at we get those a lot, what we do is wet sand with 800, 1000, and 1500. then we just put 2 coats of clear coat on it, so the haze won't ever come back and you can wax the headlights so they will be extra shiny
we charge about $75 a headlight. Check your local bodyshops for prices.
Old Nov 9, 2008 | 11:32 AM
Axel's Avatar
Axel
Or you can try using FLITZ metal polish. Works great on removing haze. Follow that with a little wax and you are good to go.
Old Nov 9, 2008 | 04:18 PM
Toby-22's Avatar
Toby-22
I would used PlastX. They worked great for me! I wetsanded mine but the biggest difference came when i used the PlastX. It's only like $8 so it wouldn't hurt to give that a try before doing anything else.
Old Nov 9, 2008 | 04:35 PM
Nexx's Avatar
Nexx
am i the only who uses plastx everytime i was the car?
Old Nov 9, 2008 | 08:38 PM
2k6-z33's Avatar
2k6-z33
Originally Posted by waizzz
I've tried 3-4 different products including one that required that I wet sand the outside of the light.
The only thing that worked out of everything that I used is called Quixx.
I applied it in July and its still looking perfect.
This stuff works
Old Nov 9, 2008 | 11:28 PM
Sponge's Avatar
Sponge
LOL No, you're not the only one. I clay bar the lense, buff it with PlasticX followed by Aerospace Protectant 303, cause it has UV protection. My lenses are crystal clear.
Old Nov 11, 2008 | 02:47 AM
SnakeBitten's Avatar
SnakeBitten
It says its for paint. But you used it on the plastic lens and the rest of car? If so Ill pick it up and do my whole car....
Old Nov 11, 2008 | 04:35 AM
Ghost_shift's Avatar
Ghost_shift
Wolfgang will work.
http://www.wolfgangcarcare.com/heleca.html
Old Nov 15, 2008 | 03:26 PM
Cannysage's Avatar
Cannysage
mine's got the same dilio on the inside of the headlights.. is there a DIY of cleaning the inside?
Old Nov 15, 2008 | 06:57 PM
cheshirecat79's Avatar
cheshirecat79
I would imagine it would be the same cleaning process described here combined with the headlight disassembly outlined in the headlight painting in the DIY forum.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350Z_Al
Oct 29, 2020 07:44 PM
JGee450
Sep 30, 2015 04:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
