how the hell do you get the rear wiper off!!???
Old Aug 18, 2003 | 06:17 AM
CarFanatic's Avatar
CarFanatic
Default how the hell do you get the rear wiper off!!???
I pulled the cap off and unscrewed the bolt. And the dang thing will not budge. Is there some kind of trick to it? Please help
thanks
Old Aug 18, 2003 | 06:33 AM
EnthuZ's Avatar
EnthuZ
Try twisting & wigglying, while lifting. It WILL come off.
Old Aug 18, 2003 | 10:17 AM
CarFanatic's Avatar
CarFanatic
I tried that the damn thing wont budge. it actually pulls the metal up as well. is there another bolt or something I'm missing?
Old Aug 18, 2003 | 11:17 AM
alphared's Avatar
alphared
i figure a picture is worth a thousand words
Attached Thumbnails how the hell do you get the rear wiper off!!???-rear.jpg
Old Aug 18, 2003 | 12:53 PM
CarFanatic's Avatar
CarFanatic
well, I guess I just have to keep tugging on it. I swear the damn thing is stuck on there pretty dang well.
alphred where did u get that picture at?
Old Aug 18, 2003 | 01:50 PM
EnthuZ's Avatar
EnthuZ
Getting a bit more specific, lift the rear most part of the arm, it's spring loaded, then try twisting, while lifting. Good luck!
Old Aug 18, 2003 | 04:11 PM
CarFanatic's Avatar
CarFanatic
the rear most part, meaning up where th wiper is or where hte bolt is? Also min has a spring in it, but you cant pull it up like you can the front wipers
Old Aug 18, 2003 | 08:56 PM
alphared's Avatar
alphared
yeah, eat your wheaties and pull harder. pic came from the service manual.
Old Aug 18, 2003 | 08:57 PM
dmzx's Avatar
dmzx
Default Try this...
I made a makeshift puller like a gear puller out of two pieces of metal about 4 inches long, bent on both ends 90 degrees about an inch with a hole drilled in one of the bent sides on both pieces. then put a bolt with a nut on the inside of the metal brackets, put the ends under the wiper arm carefully, put a wrench on the
nut while turning the bolt onto the wiper stud and it should come off easy.
Old Aug 19, 2003 | 05:47 AM
havabooz's Avatar
havabooz
dont take it off....its kinda funny that im reading this thread right now...cause this morn i needed the wiper to get the condensation off the car
ull end up needing it sooner or later
Old Aug 19, 2003 | 05:53 AM
CarFanatic's Avatar
CarFanatic
my car sits in the garage. I'm not worried about it.
Old Aug 19, 2003 | 10:43 AM
jj1814's Avatar
jj1814
where in cincy are you? ive seen only one other PPW around - parks behind the Greyhound station downtown sometimes.
Old Aug 19, 2003 | 12:30 PM
CarFanatic's Avatar
CarFanatic
I live in blue ash. I have only seen one other ppw in cincy.
I put up a post in the regions forum about a cincy meet check it out
Old Sep 11, 2003 | 08:51 PM
Z-INCOGNITO's Avatar
Z-INCOGNITO
what sux about the wiper is that... it barely lifts when you are washing your car...
Old Sep 11, 2003 | 10:46 PM
CarFanatic's Avatar
CarFanatic
I still cant get the damn thing off!
Old Sep 12, 2003 | 12:40 AM
Phatmitzu's Avatar
Phatmitzu
Try some WD40.
Old Sep 12, 2003 | 05:13 AM
jran76's Avatar
jran76
YOU HAVE TO SCREW IT OFF, spin it around as you slightly lift up on it, it spins around about 1080 degrees and will come off, only 5-6 threads are holding it on. Oh, an go counter clockwise.
DO NOT JUST PULL UP!
I have actually done this.....
Attached Thumbnails how the hell do you get the rear wiper off!!???-back2l.jpg
Old Sep 12, 2003 | 05:18 AM
CarFanatic's Avatar
CarFanatic
I tried to unscrew it to it would just start to bend wen I went to push it. I'm convinced mine is not coming off.
Old Sep 13, 2003 | 09:41 AM
Scafremon's Avatar
Scafremon
Jran76,
Did you ever come up with a different plug for the hole?
Old Sep 13, 2003 | 10:29 AM
dmzx's Avatar
dmzx
Default A little something like this...
This is what I did...The homemade puller I made..
Attached Thumbnails how the hell do you get the rear wiper off!!???-wiper.jpg
