Varis Arising 1 Sides
Old Nov 26, 2008 | 01:40 AM
415mm's Avatar
415mm
Professional
Originally Posted by ctwentytwo
The green areas is where the cracks were. It was pretty bad, but the structure was still pretty good. The red areas are where the CF is still present, but resin had to be filled over it because the area was crushed inward.
I "V" cut the green areas (slant cut the cracks) with a dremel so that the resin would hang on it and to remove loose debris.
Use epoxy resin used for marine (boat) use. Do an "epoxy resin vs. polyester resin (the stuff you can get a Wal-Mart... under the Bondo brand) and you can find out the positives of using epoxy resin. You'll need the resin, as well as a hardener. Get a gel viscosity hardener so that the resin is less runny... you want a gel consistency.
If you need structural integrity, buy fiberglass cloth and soak it in the resin and put it behind the crack, then fill in the crack. In this case, I could not put cloth behind the crack cause the skirts are shaped that they are hollow. I just used enough epoxy to make sure it is tough enough to take the bumps and vibrations of road use.
Or you can use something called "solarez." Get the epoxy version. It's used to fill in dings for surboards, and dries very quickly. It is easier to use. It comes in a tube, and you just apply, set it in the sun to harden, and in 30min, you can shape.
I used epoxy solarez for the cracks cause it does not run, and used 2-part marine epoxy resin to fill in the red parts in the picture that was "pushed in."
The marine resin comes out more clear, although Solarez is clear if it's a thin layer.
After you fill, sand to shape, then use fine grit sandpaper to smooth, then buff with a buffer to shine.
In this case, buffing it out shows the CF damage. The side skirt will be painted... at least part of it.
Great advice here ^. just thought i should add that if you plan on adding some fiberglass cloth it might be a good idea to run some 40 - 80 grit sandpaper over the area they are going to lay the cloth over so it holds and prevents any problems down the road. obviously it could be difficult to do that depending on the application but will help later down the road.
btw those sides look great and them being rare is very nice. 8 months for some sides must have been killer though.
Old Nov 26, 2008 | 04:50 AM
buzzardmountain's Avatar
buzzardmountain
God, now I want the Chargespeed sides, with the Varis Arising 1 rears (vortex generators).
A lot of people would want those......
Hell...I want my vortex generators.
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
