Brighter Headlights?
Old Dec 3, 2008 | 07:44 AM
Ivory's Avatar
Ivory
LOL.... I guarantee they are not rated for 55watts. You are getting 35watt bulbs overboosted to 55watt (or more like 42 watts) from the ballasts. How would I know? test for yourself, a overboosted bulb will burn much hotter than an actual 50watt bulb (which Philips makes) Believe what you want I suppose.
Old Dec 3, 2008 | 08:24 AM
nothix's Avatar
nothix
would it be possible to take the HIDs from my 03 headlights and retro fit them into my 95 altima DD?
those lights SUCK!!!
Old Dec 3, 2008 | 08:41 AM
Ivory's Avatar
Ivory
it is possible but not worth the effort. better to buy some projectors and retrofit those.
Old Dec 3, 2008 | 08:52 AM
datsunHEAD's Avatar
datsunHEAD
i seen a couple member selling d2r or(i forgot) dsr bulbs 6000k are those any good?i think the jdm ones?
Old Dec 3, 2008 | 09:19 AM
Bumpinjeep's Avatar
Bumpinjeep
Please dont rice out your headlights. Look into getting a used set of 06+ headlights and you will be set for cheap.
Old Dec 3, 2008 | 10:48 AM
350z-Jim's Avatar
350z-Jim
The higher the Kalvin rating (K) the less light output you get. Your stock headlights are 4300k so going to a 6000k bulb will give you less light as well as the light will look blue like the fake Xenon halogen bulbs with a blue coating on them.
I would suggest you buy new 4300k bulbs. The bulbs, even HID's, lose power and light output over time. Also "thinking" your alignment is fine has nothing to do with it really being fine. I would guess your alignment is out even if you have never touched them. It's like your wheels alignment. It will change with time even if you don't hit a curb or do anything to have it come out of alignment.
I would also check the grounding to the ballast if they appear dim. If the grounds are weak add an additional ground to the harness / ballast casing should also help if that is the problem.
The cut off of the lights is not really that far up the road, so I am wondering if you just feel like you want light farther ahead of the car than the OE lights provide? This is demonstrated by the need to turn on the high beams. If the alignment is fine like you say, I think you need to get over the fact that there isn't light shining out 500ft in front of the car like the high beams provide. Many people think they can't see as far with HID's because of the strong cut off, where halogen lights typically don't have a strong cut off and "appear" as if they are shining farther up the road.
Old Dec 3, 2008 | 11:05 AM
300zx1985's Avatar
300zx1985
I put 55w 6000k hid's in my base and night vision is great now.
Old Dec 3, 2008 | 04:58 PM
Konvict's Avatar
Konvict
Thansk alot for your input
Everyone who gets in my car says my hedlights are 'dim' and by my eyes it seems so too...i'll try to do a test to see if they really are
Also i'll have someone check out the wiring parts you suggested..i dont know much about headlights so im not sure what to look for..will have my shop look at it and possibly replace the bulbs and see if that helps...the car is a 2003 and the bulbs have never been changed
Old Dec 3, 2008 | 05:02 PM
Ivory's Avatar
Ivory
Option 1 - new OEM bulbs
Option 2 - new headlights
Option 3 - new 06 headlights
Option 4 - retrofit
Old Dec 4, 2008 | 04:33 AM
robbinsj's Avatar
robbinsj
Originally Posted by dj.kickz
says the guy whos spent hundreds on badges.
You must be thinking of someone else.
Old Dec 4, 2008 | 04:38 AM
robbinsj's Avatar
robbinsj
Originally Posted by Z04
touche' i was going to say that i paid nowhere near that amount for my cincity mod.
You must of modded your own lights then cuss the OP would pay that if following the instruction of buying 06 - 08 lights and then modding with the STI lens in cin city style.
Old Dec 4, 2008 | 08:53 AM
sam2944's Avatar
sam2944
Hello, I own www.sagahid.com. Here are my recomendations:
1. Polish the headlamps lenses. May be hand or machine polish (thin compound)
2. Confirm they are well aligned
3. Replace the bulbs for new 5000K, they have the more lumens output
4. You may want to add a conversion kit for hi beams
I personally own a 2004 Z. They do not offer much light due to oem configuration of bulb pattern and projector type.
If there is something else I may help just PM me.
Good luck!
4.
Old Dec 5, 2008 | 12:44 PM
Konvict's Avatar
Konvict
thanks for advice...im wondering if i just put fog lamps in would that brighten things up a bit? i have spots for them and have been meanning to get it done
i'll double check the stuff sam2944- cheers
Old Sep 1, 2009 | 04:29 PM
GA_VQ's Avatar
GA_VQ
Where's the best place to buy 06+ lights? I've done quite a bit of looking but only found one lamp that was actually 06+.
Old Sep 2, 2009 | 12:09 PM
misterniceguy's Avatar
misterniceguy
So where do you get 55w ballasts to brighten up the headlights?
Old Sep 2, 2009 | 12:24 PM
Jun's Avatar
Jun
Adjust your headlight beams about 2" higher.
You will see a lot more, and enough not to blind other drivers.
They are aimed low from factory.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
