'06 HID Problem - Please Help!!!
Old Dec 11, 2008 | 08:41 AM
kh_08's Avatar
kh_08
Default '06 HID Problem - Please Help!!!
Hey guys,
I have a ’03 Touring which I updated with the new ’06 headlights. The problem is that the light output is bad (stock bulbs were not changed). I thought it might have been due to the HID ballast it came with, so I swapped it with my original; no difference. I compared it to the output to that of many local car club members and there is a considerable loss of power in mine. Anybody have an idea as to what might be wrong? Is this electrical, bad ballast or something else?
I’m considering buying a quality aftermarket hid kit (if there is such a thing)…
-Thanks,
K. Harbie
Old Dec 11, 2008 | 09:19 AM
kh_08's Avatar
kh_08
Help.... Anyone???... ... I can't see...me have no lights & it's getting dark over here...
Old Dec 11, 2008 | 09:24 AM
KornerCarver's Avatar
KornerCarver
I suspect you need some new lights. I believe you said you did not change the stock light bulbs. The 2003 has D2R lights and the 2006 headlights require D2S capsules. That might be the root of your problem.
Les
Old Dec 11, 2008 | 10:14 AM
kh_08's Avatar
kh_08
Thanks a lot Les. I'll check into that.
Old Dec 11, 2008 | 10:30 AM
kh_08's Avatar
kh_08
The fact is that I currently have the wiring and sockets from my '03 in the new '06 housing. So, will the D2S bulb fit into my D2R socket and not negatively affect the light output?
-thanks
Old Dec 11, 2008 | 03:33 PM
KornerCarver
Good question. I really don't know the answer to that one. You need the new bulbs D2S bulbs anyway so why not just stick them in and see how the light output is? If I understand it correctly, the D2R is a reflector type bulb and the D2S is for a true projector lens. The 2006 lights are true projectors while the 2003 are not.
Old Dec 11, 2008 | 05:47 PM
RanFerr_350z's Avatar
RanFerr_350z
-thanks
it should work. i swapped out my 05 hid's for 06 headlights, switched the bulbs and it works fine.
Old Dec 12, 2008 | 04:45 PM
kh_08's Avatar
kh_08
Cool thanks a lot guys
Old Dec 14, 2008 | 04:39 PM
sam2944's Avatar
sam2944
If need something about HID just let me know (PM) www.sagahid.com
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
