350z Gauge cluster
Old Jan 11, 2009 | 08:32 AM
Devil_Z's Avatar
Devil_Z
Default 350z Gauge cluster
im looking to see how to take off the main gauge cluster on my car. Cause my car is from the states that has MPH instead of KM/HR,and the fact that I live in canada. Having KM/HR is a big deal to me. Ive looked up the owners manual and other sites for this car and no one has to have the specific amount of info to do it. If any member can show me pictures and the procesier how to take it off please write on this fourm.
Old Jan 11, 2009 | 01:48 PM
Barnabas's Avatar
Barnabas
National Z Club President
Main Gauge Pod – Lift the steering wheel as high as possible, you will find 4 screws under the column (one screw will be under the lever), take them out. Remove the key hole trim ring. Take a small flat head screw driver (wrap it in tape to protect your plastic pieces if you wish) and pry open the bottom half of the steering wheel column from both sides, the piece should pop off with some work. Move that piece out of the way and there will be 4 bolts that need to be removed (these bolts hold the main gauge cluster in). The two rear bolts should be facing straight down, while the front two bolts will be roughly at a 45 degree angle. Remove the bolts, lift up the gauge cluster, and unplug the wire harness.
AC Controls – Lift up the lower console panel ring by placing your hands under the piece through the shifter boot and pop the lower console off. Unplug the wire harness and unscrew any screws that are holding down the AC controller unit.
Triple Gauge Pod – This will pick up from the AC control removal above. Remove the two Phillips screws at each bottom corner of the radio. Open the center cubby and remove the mat inside, this will expose a few screws, remove them. In the cubby, remove the bezel cover and remove two more screws deep in the pocket with a long Phillips screwdriver (I would advise a magnetic version to avoid losing the screws). Find a few more screws under the AC control and remove them as well. Now gently pull on the lower part of the center console a little, it will pop out, do not try to remove it at this time (if the center console is not budging, re-check for any left over screws that may have been forgotten). With the lower portion of the center console loose and SUPPORTED, grasp the top of the center console near the windshield and gently pull the console toward you. Unplug the wire harness to the triple gauge pod; unscrew the screws holding the triple gauge pod to the center console.
Old Jan 11, 2009 | 01:52 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
^very helpful info right there, good to know
Old Jan 11, 2009 | 03:11 PM
Barnabas's Avatar
Barnabas
No problem
Sorry I don't have pics to post of each step. maybe someone else does??
Old Jan 11, 2009 | 07:39 PM
Devil_Z's Avatar
Devil_Z
thanks Barnabas u rock!!
Old Jan 13, 2009 | 05:52 AM
TreeZ's Avatar
TreeZ
those instructions look very familiar...
Old Jan 13, 2009 | 11:39 AM
dcash5's Avatar
dcash5
From the UK forum
http://www.350z-uk.com/forums/viewtopic.php?t=14526
Old Jan 13, 2009 | 01:22 PM
Barnabas's Avatar
Barnabas
TreeZ gets credit for those.... He is the one who wrote them up I had them saved from the group buy.
Give him the credit for the work. Im sure its out there more then just here and im sure google could turn stuff up too. I just posted the easiest available instructions.
Old Jan 13, 2009 | 08:52 PM
Devil_Z's Avatar
Devil_Z
thanks anyways its every useful info but the pictures dont exist for that site
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
