Rear "diffusers" install information
Old Aug 29, 2003 | 02:40 PM
sparky3Z's Avatar
sparky3Z
Default Rear "diffusers" install information
This information was requested by Conceyted and I thought I would post it here for others benefit.
__________________________
The two diffuser part numbers are included in the following information given to me (thanks!) by reenmachine and ChinaClipper. Note one side takes two nuts and the other side two bolts. These diffusers are black plastic and the left and right are quite different in shape. It took me about 10 minutes a side to install them. You have to drill one hole on each side of the existing plastic inner fender liner for one of the clips. It will be obvious where to drill once you figure out how the diffusers fit in behind the wheel. I installed mine without removing the rear wheels or raising the rear.
___________________________
Author:_ reenmachine _(---.242.8.67.cfl.rr.com)
Required stuff (according to "A17Z"):
Driver side
2 - 10mm nuts (sparky3Z: this is the wrench size, NOT the hole size—I think it was 6mm but it may have been 5mm. You can check before buying.)
2 - plastic fasteners (clips)
1 - rear driver side diffuser 748A0 CD810
Passenger side
2 - 10mm bolts (sparky3Z: this is the wrench size, NOT the bolt diameter—I think it was 6mm but it may have been 5mm. You can check before buying.)
1 - rear passenger side diffuser 748A0 CD800
Threads:
https://my350z.com/forum/showthread....track+diffuser
__________________________________
The following photo and comments are by ChinaClipper:
Shot of the Left rear diffuser.
This shot is taken from directly behind and underneath the car, looking up and forward towards the left rear wheel well with the tire and wheel removed.
Old Aug 29, 2003 | 02:47 PM
sparky3Z's Avatar
sparky3Z
I bought mine from:
http://www.courtesyparts.com/
Old Aug 29, 2003 | 03:01 PM
LowUFO's Avatar
LowUFO
Price?
Old Aug 29, 2003 | 04:35 PM
sparky3Z's Avatar
sparky3Z
The two diffusers were $28.99 each ($35.83 list) and the clips were $2.52 for four. The part number for the clips is 01553-09321.
Old Aug 29, 2003 | 04:55 PM
Conceyted's Avatar
Conceyted
i appreciate it! thank you
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
