Remove HID bulb from 2006 headlights
Old Feb 18, 2009 | 10:32 AM
Mathys's Avatar
Mathys
Default Remove HID bulb from 2006 headlights
Just wondering how to remove the HID bulb from OEM 2006+ headlights . Which way do you twist or can you pull them straight out? I had a quick look, but didn't manage. I don't want to break them, so anyone a hint?
Tnx
Old Feb 18, 2009 | 11:56 AM
Brandon26pdx's Avatar
Brandon26pdx
Not sure, but if you havent, you'll want to disconnect the battery before you touch anything HID related.
Old Feb 18, 2009 | 12:06 PM
boostintt's Avatar
boostintt
im not sure if its the same, but im replacing mine on my 03... im putting some d2r 10000k. i'll take some pics and post them if its a similar process
Old Feb 18, 2009 | 12:38 PM
dleariousz's Avatar
dleariousz
From my experience with mine, there is a metal tab that pulls over and behind the bulb then the whole bulb assembly twists maybe a quarter turn the pulls straight out then just pull out the hid bulb by the base of the bulb!!! Thats how I did mine on my 06 and it works just fine!!!
Old Feb 18, 2009 | 08:53 PM
Mathys's Avatar
Mathys
Tnx for the input!
Old Feb 18, 2009 | 11:30 PM
KYEXTAZ's Avatar
KYEXTAZ
remove white round cap counter clock, take off silver harness by turning from like 12 to 11 oclock and pull off, then squeeze the two (V shaped) metal prong like things holding the bulb in and it pulls down out of the way and the bulb removes easily and then reverse to put it all back
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
3vilbunny
Jul 18, 2017 05:10 PM
JGee450
Sep 30, 2015 04:32 AM
