Carbon Fiber Vinyl Pattern Wrap Thread
Old Sep 1, 2010 | 07:03 PM
  #541
KingBaby's Avatar
KingBaby
Hardest Setting
curious you are?
I'll post pics of what mines looks like a year later...
tomorrow
  #542
phreaktor's Avatar
phreaktor
Design Engineer
Thanks
Old Sep 2, 2010 | 09:21 PM
  #543
KingBaby's Avatar
KingBaby
Hardest Setting
all in all it was a cool mod, I get complements on who did it all the time..
if you have time and the patience to keep the parts out the car for a day or so so that it can dry without fighting the sun...it will last longer!
I'm looking into the Di-noc stuff now
Old Sep 14, 2010 | 06:05 AM
  #544
js4506's Avatar
js4506
Default Di-Noc wrapping questions
Hey, Im thinking about wrapping my center console area with the "carbon fiber" Di-noc and was wondering for those who have done it, if there was any parts that were trouble doing? I was wondering how you would wrap it by the button on the cubby because it seems like it would make the button stick
If anyone has any tips for me when i do it thatd be great,
Thanks
Old Sep 14, 2010 | 09:49 AM
  #545
350Z_Al's Avatar
350Z_Al
Thanks
I don't think you'll have an issue around the button, the di-noc material is so thin. I wrapped my console but I no longer have the button as I have molded in an 8.5" lcd screen in it's place.
I also sanded mine smooth prior to wrapping it. I was originally going to paint it body color, but ended up wrapping in the di-noc instead. I'm not sure how well the di-noc will stick to the factory textured parts.
As for wrapping it, take your time, use a hair dryer or heat gun to help make the material softer and help it contour to your parts and stretch easier. Make sure your surface is very clean prior to starting (I did my laptop but didn't clean it to well and the edges are starting to peal).
Old Sep 14, 2010 | 11:17 AM
  #546
js4506's Avatar
js4506
ok thanks alot! did you have to cut releif slits when wrapping it around the corners to make sure it didnt wrinkle up? or did it just stretch nicely around the sides? and i dont need to buy any adhesive do I, it comes backed with adhesive?
Happen to have any pics of yours finished?
Old Sep 17, 2010 | 11:40 AM
  #547
Jun's Avatar
Jun
Would using the 3M adhesive spray glue in addition to the self-adhesive be a good idea or not?
Old Sep 19, 2010 | 09:44 AM
  #548
350Z_Al's Avatar
350Z_Al
No relief slits, just heat and stretch.
It does have the adhesive already on the back so no need for additional adhesives.
Probably not a good idea. I talked to the 3M supplier I bought my material from and they said that the material is intended to be installed dry and not to use any application fluids or additional adhesives.
Old Sep 21, 2010 | 12:10 AM
  #549
ctwentytwo's Avatar
ctwentytwo
Your first time to try will be a pita. Seriously. But as you get good at it, it becomes easier. I would try wrapping another part first, because the center console can be tricky. I just wiped the surface with some alcohol.
The other pita thing is just getting some of the stuff apart so you can wrap underneath so when you reassemble, it won't peel off- ie: the cubby door.
I posted these awhile ago... you can see the various progression of wrapping... from the center console only, to the door panels.
Yes... I actually cut out the monitor controls and molded it in the cubby finsiher... which I can't believe nobody notices...
Old Sep 21, 2010 | 01:35 AM
  #550
dmroberson's Avatar
dmroberson
How big of a roll did you have to get to do all this? I've been looking at doing this myself.
Old Sep 21, 2010 | 09:39 AM
  #551
Tackett's Avatar
Tackett
Damn I want to do that.
The site says that you can clear coat the stuff as well. I want to give this a shot at some point.
Old Sep 21, 2010 | 10:20 AM
  #552
Erik@R/Ttuning's Avatar
Erik@R/Ttuning
Their site says you can clear it but everything I have read from end users says not too.
Old Sep 21, 2010 | 10:32 AM
  #553
HeyItsDan's Avatar
HeyItsDan
I'm wondering the same thing
Old Sep 21, 2010 | 10:35 AM
  #554
shaun123's Avatar
shaun123
that looks amazing cttwentytwo. I would like to do that sometime to my car
Old Sep 21, 2010 | 10:50 AM
  #555
zaperroni's Avatar
zaperroni
You can also use it for other parts of the car.
Old Sep 21, 2010 | 05:54 PM
  #556
happyzday's Avatar
happyzday
so I'm assuming the best place to order the vinyl is neffywrap . com? I want to do this asap!
Old Sep 21, 2010 | 06:02 PM
  #557
ctwentytwo's Avatar
ctwentytwo
2ft x 4ft. It's more than enough to do the center console, shift boot area, both inner door handles, and inner passenger pull handle. You'll have extra to do some other small areas if you want to go overboard.
Old Sep 21, 2010 | 06:12 PM
  #558
ZS14RR's Avatar
ZS14RR
how much was it and where did you get it from?
Old Sep 21, 2010 | 06:15 PM
  #559
ctwentytwo's Avatar
ctwentytwo
Sorry OP, don't mean to get off topic....
Read through this thread:
https://my350z.com/forum/exterior-an...-interior.html
Old Sep 30, 2010 | 09:04 PM
  #560
hagar2sail's Avatar
hagar2sail
As I understand it after reading all 26 pages (cheer for me!) is this isn't vinyl it is a cloth product that has to be applied with an adhesive.
I just wrapped a few parts in my f150 with a vinyl carbon fiber product from some shady ebay guy that another f150 forum member had good luck with (not Di-noc). I have been having issues already with it lifting in places even though it hasn't been above 60 degrees here in Maine for the whole week. Thinking about trying this stuff in it's place before approaching the Z.
