Someone help...simple yet important question
ok..i installed my veilside version 1 underwings last night
it was pretty much cake work
but actually i have a few concerns
#1--when installing both of the rear ones..i had to remove this rubbery piece off the bottom of the sideskirt(underneath)
if you run your hand along the skirt and finally get to the back there is like a rubber flap...but i needed clean acces to the bolt on the other side of the flap..so i removed it
what is it
MORE IMPORTANTLY
my front underwings are only secured by 1 bolt...they are supposed to be by 2...but heres my problem..
one of the bolts that has to be used is covered with like a black (seems to be snap off) piece....i know that its a bolt even though it cant be unscrewed in its current state (i know its a bolt becase i can feel the top of it on the topside of the skirt
this question may sound hard...but its not
basically im just askin how to get that black peice off so i can use the bolt for the underwing
im not sure if you will see it with the mudflap on (because i took mine off)...but you might
anyway...i just wrote a freakin scroll to ask a simple question
haha..thanks for your help
what is it
MORE IMPORTANTLY
