bought a CF hood (yeh im the guinea pig)..need help though
Old Sep 15, 2003 | 04:13 PM
Chebosto's Avatar
Chebosto
the edge of the hood, where they attach the stock latch, yes. but no x brace or anything of that nature in the middle.. no need.
the reason for carbon hood is to keep the weight down (traditionally)
hood pins attach to your front frame section or sides of the fender.
where ever you can get a hard mount.
Originally posted by Mike Wazowski
does fiberimages use FRP undercarriage?
Old Sep 15, 2003 | 05:38 PM
havabooz's Avatar
havabooz
what are the best hood pins to get..preferrably black
Old Sep 15, 2003 | 06:39 PM
JPizzle's Avatar
JPizzle
ahh, yo quiero photografias
Old Sep 15, 2003 | 08:33 PM
Chebosto's Avatar
Chebosto
the best hood pins are the ones that have the cotterpins that slide into a rig.. ala single unit so some jackhole cant swipe your cotter pins.
cusco makes a good set.. ~$50 for two... you can always get generic ones-- mister Gasket co. makes a cheap set for $13 but they are the removable cotter pin style..
Old Sep 15, 2003 | 08:35 PM
havabooz's Avatar
havabooz
only the best for my Z..cusco is the maker..what is the model
and obviously you have to drill into the hood (that scares me)
can i do that myself??
Old Sep 15, 2003 | 08:37 PM
JPizzle's Avatar
JPizzle
drill a lot of holes, then your hood would be really light
Old Sep 15, 2003 | 08:44 PM
havabooz's Avatar
havabooz
be serious here man!!...or no pics for you!!!!
im the pic ****
Old Sep 15, 2003 | 08:48 PM
JPizzle's Avatar
JPizzle
im sorry
You can drill your own holes, just make sure to mark where u have to drill
Old Sep 15, 2003 | 08:49 PM
havabooz's Avatar
havabooz
i was just jk
i have no idea where to drill..and i do not desire to screw up a hood i just bought with pins that i dont really want in the first place
therefore i will take it to a proffesional
Old Sep 15, 2003 | 08:51 PM
JPizzle's Avatar
JPizzle
well, that's the one route, but don't you wanna take the road less traveled (and cheaper?)
Old Sep 15, 2003 | 08:52 PM
havabooz's Avatar
havabooz
i dont even have the proper tool
anyway..its study time...hopefully the next time i visit the forum it will be the time i post pics and wieght
nighty night
Old Sep 15, 2003 | 08:54 PM
JPizzle's Avatar
JPizzle
hmm, I wish I could go nighty night, I'm almost finished with my ap bio paper =\
Old Sep 15, 2003 | 09:52 PM
mgl's Avatar
mgl
get the hood pins with the lock and key. they on are on the rsx in the sig. the pins are made by cusco. they pins cost $60, and the same price for install. so basically $120 for everything. i would strongly suggest you not to do this yourself as i heard that it is hazardous to breathe in the carbon fiber. also the installation looked pretty difficult.
Old Sep 16, 2003 | 02:43 AM
DeeZee's Avatar
DeeZee
nice to hear you like the hood (no blemishes) sounds great, cant wait to see it!
Old Sep 16, 2003 | 05:51 AM
havabooz's Avatar
havabooz
mgl..there are 4 types of cusco pins (i did some searching)
they are called type 1 2 3 and 4
on some sites it says that types 1 and 2 are stronger
any idea which ones you have
and do you have a closeup pic...preferrably of the underside of the hood
if not any info is appreciated
thanks
Old Sep 16, 2003 | 08:53 AM
Chebosto's Avatar
Chebosto
if you are drilling into carbon fiber
USE PROTECTION AT ALL COSTS!!!!!!!!!!!!!!!!
wear long sleeves, taped up at the wrists and use rubber gloves (dish washer type)
Carbon fiber is very dangerous to your health if the dust is inhales.. use a high filtration device for a mask, and in a well ventilated area.
if carbon strands come in contact with the skin it will feel itchy. DO NOT SCRATCH IT! it will just embed it self into the skin even more, use DUCT tape or high-sticky packaging tape lay it on the skin and lift up and away to get as much of the dust off as possible, then wash with COLD water to close your pores.. i cant stress this enough.... carbon is nasty and will take a long time for your body to decompose it-- if ever.
before cutting/drilling already cured carbon, set up tape/masking tape over your the hole you wish to make.. on the top and bottom to prevent splintering. use a high speed drill and sharp/preferrably new drill bit and go gradual sizing.. from small drill bit to larger until you fit your size hood pin. if you go too big to fast you might crack the carbon.
have a friend use a vaccuum underneath the hood so you dont have a chance to suck up the dust particles...
just a warning if you plan on installing pins yourself..
also.. look at sparco.. they're just as nice as the cusco ones.
edit:
http://info.product-finder.net/finis...HOOD-PINS.html
http://www.racerwheel.com/exterior-hood-pins.html
http://store.summitracing.com/produc...earchtype=ecat
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
