help: installed seats now airbag lights is flashing
Old Mar 30, 2009 | 08:29 PM
FairLadyz916's Avatar
FairLadyz916
Default help: installed seats now airbag lights is flashing
guys i need some help for those with aftermarket seats. i just got done installed my new seats today..there was two clips on the bottom of the seat ( one seat belt one airbag ) the transfer the seat belt but not the airbag. now the airbag lights i just flashing. is there anyway to transfer that plug or should i just leave that light flashing??
the plug for the airbag seems to be installed in the seat itself.
any suggestions? thanks
btw: i have an 06 base.
Old Mar 31, 2009 | 12:38 AM
SageZ's Avatar
SageZ
Originally Posted by FairLadyz916
is there anyway to transfer that plug or should i just leave that light flashing??.
just leave it flashing..
Old Mar 31, 2009 | 06:34 AM
h-Z's Avatar
h-Z
Default Take it to the dealer
I had the same issue when I got my seats done last month.
While at the dealer (for an unrelated issue) the dealer reset the airbag warning for no charge.
Old Mar 31, 2009 | 06:47 AM
crg914's Avatar
crg914
If you don't mind your SRS system being disabled then just leave it flashing.
If you have the dealer reset and leave it as is it will just turn back on because the seat occupancy system isn't there anymore after you installed aftermarket seats.
Read through this thread. It gives you all the information you need to keep the system active and properly reset the light. You either need to move the bladder or get the warning cancel harness for everything to properly function.
Old Mar 31, 2009 | 10:11 AM
na_350z's Avatar
na_350z
Quick question this would only pertain to replacing seats with aftermarket seats but only if your original seats had the side air bags built into the seats right?
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
