After 5 yrs and 70KM, MY OEM HIDs are BURNT!!!
Hi guys I always turn on my hids during the day and after 5 yrs the blubs are gone. My left went purple couple days ago and tonight its all gone.
how much does nissan sell the factor D2R bulbs for anyone knows? probabaly gonna get ripped off from them. Anyone know a good site to order aftermarket bulbs perhpas philips 5000k?
thx guys=)
thx guys=)
Well considering you have had your car for 5 years I'm going to assume you don't have the new 06+ headlights meaning you dont' have xenons. I'm not sure how the HID's work but for xenons you just take off yoru front bumper, take off the 4 screws for the headlights then pull out the old bulb and pop in the new one. I assume the HID headlights are the same but the bulb is goign to much much cheaper.
Arsh, you don't have to remove the whole bumper to just get to the bulb... all you have to do is turn the wheel outward (the side you are working on), raise the car on a stand (gives you more working space and remove the plastic panel behind the headlight, unlatch the bulb and switch it. The process took me about an hour, but it wasnt bad.
There is a DIY somewhere here on the forums. Do the search, it'll have pics with it as well. Oh and stock bulbs if I remember are registered at 4300K-4500K..
i have a 04 it is hid and looks white but i am not sure if it is xenon..meaning there is xenon gas for brighter output?
what bulbs should i be looking for to replace my oem ones?
And stock is 4300 but I wanted 6000k for straight up white light. Just preference
You don't have xexon. Only the 06+ headlights come with xenon which are better than the HID but you can't really upgrade from your setup unles you buy new 06+ headlighst which a lot fo peopel do but they are expensive.
Xenon (HID) was offered in the 03 cars as well as the 06. The only difference is the 06 has a projector housing with the HID in it vs. the 03 with the wierd projector that sits in front of the reflector housing. My car is an 03 and I absolutely assure you it has HID (xenon) lights. Only base models had halogen, ever other trim level was HID.
Either way they are both HID (xenon) lights just different housings.
See the ballast and HID bulb?
My bad, I didn't know the exact terms to use but the point I was trying to get across was that the type of bulb he woudl need to buy would be different from my headlgihts because i ahve teh projector. And I believe the type of bulb he needs is much cheaper than D2S bulbs. That's what I was trying to get across, I appologize for not bieng right about the terms I used.
Either bulb is generally about $35 each from an aftermarket retailer now a days however.
http://www.cqlight.ca/index.php?cPat...1947945e9235d3
What are you talking about? HID and Xenon are the same thing, its simply a different word used to describe the lights. Xenon is a street term for HID lighting most commonly used in marketing when HID lamps were first offered in cars. Some companies still call them Xenon lights, other High Intensity Discharge, regardless it's the same thing.
