Help with installing quick release
Old Apr 9, 2009 | 06:03 AM
synth19's Avatar
synth19
Default Help with installing quick release
Guys, I ordered a short hub, QR, and new steering wheel. It's been about a couple years since I've done this install but when I received my quick release, I didn't recognize some extra cables. Can someone verify that the QR for the Z has these? Although this is going on an NSX, I wanted to verify if the works bell QR also had these extra cables:
I don't remember all these cables on the QR. 4 & 6 looks like the grounding cables, but I'm not sure abotu 7 & 5 (7 looks like another horn cable).
Sorry for this blurry pic, but looks like they also gave me the jumper/resistor cable for the airbag light (1), the horn cable (2), and number three? WTF is that? An extra resistor?
thanks
Old Apr 9, 2009 | 12:55 PM
Chebosto's Avatar
Chebosto
1. airbag resistor
2. horn extension
3. ?? blurry.
4. horn
5. horn ring
6. horn ring
7. ??
check with ohmeter to see if there is any resistance in wire 3..
you should be reading 2.0 - 2.2 ohms
Old Apr 9, 2009 | 01:17 PM
synth19's Avatar
synth19
Thanks man, since this post I've discovered:
#1: resistor
#2: horn (extra piece)
#3: resistor (extra piece)
#4: horn
#5: horn (grounding)
#6 horn (grounding)
#7:horn
#7 doesn't fit into the pin for the NSX horn, so I have to splice and connect #2 and #3 to fit #7 and the other side to fit the pin.
This is much easier to do for the Z!
