350z main console loose
Old Apr 18, 2009 | 04:20 PM
350z_Roadster's Avatar
350z_Roadster
Smile 350z main console loose
I removed the main console on my 350z to install a gps, once the console was put back,the top section of the console does not sit flush any more.
has this happend to any one else, and is there a fix, it seems the metal clips are now lose in their holes.
Thanks
Old Apr 18, 2009 | 06:59 PM
NISMO_558's Avatar
NISMO_558
pics would help.
Old Apr 18, 2009 | 09:23 PM
Fixxxercask's Avatar
Fixxxercask
I think I know what you mean. I just took mine out to change my gauge lights to blue and I had the same issue. Pull the top back out and feel on the back side in the very center of it, there is a tab that sticks out and needs to slide into a groove on the dash to pull it all back together flush. You can't really see it sitting in the car because its so close to the winshield. Hope this helped.
Old Apr 18, 2009 | 10:16 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Did you put all the screws back in?
There are no screws at the top but the sides are critical, also check to make sure no wires are buched up in the wrong place.
I had this happening with mine after installing an aftermarket HU, once I pulled out the big metal frame that held the stock HU in, it went together fine.
Whatever you do, don't push to hard on the three gauges, they pop in pretty easy.
Good luck,
Old Apr 20, 2009 | 03:53 AM
350z_Roadster
Thumbs up
Thanks for your help, I finally removed everything again, notice 2 metal brackets one on each side, these are installed by nissan, but I think everything is a very tight fit, so I bent back on these 2 brackets, much better, not perfect but better.
Thanks for your help, this forum is great
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
