are those manufacturer defects? or i was fooled?
I know what you're saying - I'm looking to put my OEM side skirts back on and Nissan wants ~$9 apiece for the plastic grommets and clips that hold them on! I think 3M tape would do the trick, just make sure you wash and de-grease both surfaces really well before applying the tape, and make sure you use thick enough tape (the 3M tape comes in varying thicknesses, and I would go with the thicker stuff). When you take off the side skirt you might find that the original adhesive patch (should be gray in color) is there but just no longer sticky. Measure its thickness and get some 3M that is comparable.
i found '03-'05 DIY, but i think it's a bit different..
have a look: https://my350z.com/forum/body-interi...t-removal.html
By the way, sent you a PM...
DarkCreep
Oct 17, 2015 11:50 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
