Affix front plate without drilling?
I'm in Missouri, where apparently they WILL, in fact, pull you over for not having a front plate.
Personally, the very thought of drilling into my beautiful bumper to affix the otherwise butt-ugly mounting bracket makes me cringe. Is there another solution? Is there a bracket out there that allows me to affix the plate without drilling? Maybe something that mounts lower, so as not to distract from the beautiful bumper appearance?
Ideas or links appreciated.
^ you can atleast tell him who makes it, stillen makes a kit that mounts using the tow hook.
http://www.stillen.com/product.asp?i...T01&c=EX&m=all
IMPORTANT: The bracket assembly must be completely removed whenever your 350Z is towed using the tow hook. Please keep appropriate tools handy in case of an emergency. Also, if you take your 350Z on the track, please remove the zee-bracket first.
You will need a drill and a 3/16" drill bit, as installation requires drilling two holes into the front grill.
i remember seeing some no drilling license plate holder for 60 bucks or so. It goes under the front bumper when you dont want to use it...ill check to see if i can find the link
I have no personal experience with this product, but here you go...
http://www.swiftmotorsports.com/prod...f5daea5b033163
