Where is Easiest 12v inside the z?
Old May 3, 2009 | 08:54 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Originally Posted by aloh
http://www.radioshack.com/product/in...ductId=2104093
In that picture, the black wire is the original wire you want to tap into. It is cut in half and stuck into the ends of the wire tap. The red wire in that picture represents the additional wire you wanted to connect to the existing black wires.
Actually, what you're thinking of is probably a crimp connector. The way the tap-in connectors work is you just line up the wire you want to tap into with the wire you're trying to get power from and then crimp them together using the connector. If you buy this part, you'll see how that works.
http://www.delcity.net/store/Tap-Connectors/p_9111.a_1
Originally Posted by tannerday
wo wo wo chill out.. i did not mean that at all. Im just confused of what it is. If you dont want to help me its fine im just asking everybody.
You said you searched when it's obvious you didn't. A search using any sort of search engine would have shown you what they looked like. I just don't like being lied to, especially when I'm helping you troubleshoot your problems.
BTW, here's a good link you can follow, if you're really looking to do this yourself:
http://www.mmxpress.com/technical/connections.htm
Old May 3, 2009 | 09:27 PM
aloh's Avatar
aloh
yeah i was trying to find something like the ones that came with my paddle shifters, but i coudlnt really find a picture online. I used that one as an example out of convenience.
Old May 3, 2009 | 10:18 PM
3hree5ive0ero
Retired Admin
For things like what the OP is trying to do, it doesn't matter what type of connectors he uses, but for other things that read the voltage (i.e., throttle body voltage readers), it's imperative that you use something the tap-in connectors or something similar, rather than cutting the wire (as that changes the resistance).
Old May 4, 2009 | 05:11 AM
JEKL's Avatar
JEKL
Tanner, I know I gave you a bunch of **** back before you got banned for your theads and this is exactly why. Your knowledge is so nonexistent that calling you a newb is an insult to newbs. If you do not even know what a multi meter is, then you have no business messing with the electrical system of your car. I don't want you frying it or even worse setting your car on fire one of these days!
If you really need this level of spoon feeding when it comes to electronics then please go to an electronics place like Radio Shack. They can not only give you advice but they can give you the visual that you need by showing you the parts and tools you need for the job.
And I too find it hard to believe you spent all the time you say you did searching. There is no way you went to somewhere like google and typed in something along the lines of "how to wire a LED".
Dr.Paulyy
Jul 29, 2019 07:45 AM
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
