Headlight housing question
Old May 27, 2009 | 05:49 AM
1cockyZ's Avatar
1cockyZ
Default Headlight housing question
My car was backed into and I have to replace the headlight housing.
I have a an 03' track with hid's. Can I swap all the hid hardware into a base housing? Because my car is an 03' the insurance company is saying that its $220.57 for a reconditioned headlight.
Old May 27, 2009 | 06:23 AM
davidmcc's Avatar
davidmcc
You may just have to butt heads with the insurance co. on this one. If the car came stock with HID's don't settle for anything less, and personally, I'd tell them to shove it if they told me I had to use reconditioned parts.
Old May 27, 2009 | 06:53 AM
1cockyZ's Avatar
1cockyZ
Its state law because the car is older than 06' they can do this. I think the guy screwed up and quoted a nonhid but anyway can these housings be swapped or what?
Old May 27, 2009 | 07:22 AM
usmanasif's Avatar
usmanasif
I bought some OEM base lights to get lenses off of for my 06 lights. Granted I've never seen an 03-05 HID housing before, but I can tell you that at the very minimum you will have to dremel off the mounting spot for your ballast. The base housing has the spot clearly marked and indented, but there isn't a hole there since those don't need a ballast. The only piece I'm not sure of, is whether the D2R bulb would seat correctly in the halogen mount. Rest should all be the same.
Uriyo_
Sep 8, 2021 08:46 AM
JGee450
Sep 30, 2015 04:32 AM
