odometer reading?
Old Jun 2, 2009 | 05:48 PM
TurboSam's Avatar
TurboSam
Default odometer reading?
does the cluster itself store this information, or is it the ECU or BCM?? my cluster has a major crack in the lense, and i need to know if i can simply swap clusters, or i need to do something else.
Old Jun 2, 2009 | 06:59 PM
mD2MHK's Avatar
mD2MHK
the cluster holds the odo info. if you switch it out, like i already did bc it gave incorrect info, you'll need to send it out to match the old odo, which i didnt do
Old Jun 2, 2009 | 07:06 PM
Good question. I read the function of the unified meter control unit several times. Manual reads:
The record of the odo meter is kept even if the battery cable is disconnected. The record of the trip meter
is erased when the battery cable is disconnected.
I assume record is kept means that the memory is non-volatile.
Old Jun 2, 2009 | 07:48 PM
AznKaos15's Avatar
AznKaos15
What kind of incorrect info did you get?
I think mine may be fast.
On one of my normal routes, I get 14.8 miles in my other car, I got 14.8 in a rental Altima but in my Z, it reads 15.0
How can I get my odometer switched by the dealer?
Better yet, how can a dealer even verify this?
Old Jun 2, 2009 | 07:53 PM
Check with your DMV about switching odometers. They may have some sort of validation process.
apex locator
Jul 23, 2021 02:27 AM
35reilly
Sep 28, 2015 07:42 AM
Tochigi_236
Sep 27, 2015 03:40 PM
