My personal racing bucket review. Bride, Recaro, Sparco
This is not a personal ad
I'm 5'11", 175, and 33" waist.
My first post trying to figure out what seats fit me was a failure. 166 views and no replies. I was trying to get an opinion on the Cobra Suzuka S (not GT) seat before I take a roll of the dice. From the little bit of info I got from the interweb, it seems the Suzuka S seats are for people up to 34 waist. I can't find a shop in the entire bay area that has these in stock for trial.
My review so far:
Sparco
*Pro 2000 is an awesome seat. It fits me everywhere except the shoulder harness holes are too low. The only way I could use this would be to junk the lower seat cushion (I don't like this idea). Holding is great/deep and comfortable at the same time.
*EVO fits well, but shoulder harness holes are too low for my height. Lateral support feels pretty good.
*EVO2 is a bit too large for my frame, and the shoulder harness holes are still too low. Overall height seems lower than the EVO?
*From my experience of selling a few sparco seats over the years, they look really nice when new, but don't wear well (bucket seats).
*Read on MY350Z that the sparco hardware makes the seats sit high.
*Basic L shaped/flat bottom
*FIA homologated
Bride
*Zeta III type L fits snug at the hips, but truly is a "holding monster". Taller height lines up perfect with my shoulder and the harness holes are placed just right. The material seems very nice and durable. Instead of being shaped like an "L", it's more like a J. Where as the seat bottom actually protrudes lower than a flat bottomed seat. This prolly helps with a lower seating position.
*Pretty
*Not FIA homologated
Recaro
*Profi SPG fits a bit more snug than the Zeta III in the hips, but not as much depth or "holding. The cushion has more "give". Height is fine and shoulder harness holes line up well. The material seems plush, but not as durable "feeling" as the Bride, but nicer than the Sparco material. L shaped flat bottom.
*Pretty
*FIA homologated
*Profi XL is for big people. I could put a balled fist easily on the side of both hips while seated. Like the SPG, the XL is made of the same cushy material.
*L shaped/flat bottom
*FIA homologated
*Pole Position had a little wiggle room in the seat/hip area. The material was the same as the Profi stuff. It has a very awkward/bent over feeling in the shoulder area.
*FIA homologated
So far, I like the Zeta III L's the best, even though I'd like more hip room. I may return the Zeta III if I find a better fitting seat. It sucks that only the regular Zeta III is FIA homologated (I discoverd this after my purchase
I still want to try the Cobra Suzuka S before I buy my seats. If you know anyone in the bay area with these in stock, LMK. Please feel free to add or comment, just remember to include you body size info.
My review so far:
Sparco
*FIA homologated
Bride
*Pretty
Recaro
*Pretty
*FIA homologated
*FIA homologated
*FIA homologated
).I still want to try the Cobra Suzuka S before I buy my seats. If you know anyone in the bay area with these in stock, LMK. Please feel free to add or comment, just remember to include you body size info.
I make this point because the shoulder harness can become dangerous if the angle is too great. Most tech inspections require no greater than 15-20 degrees of increasing angle in relation to the anchor point. If it is greater than this, in an accident it can actually compress the spine. With the harness holes being so low on my shoulders, the harness actually rides on the upper edge of the hole. This will in fact cause compression rather than restraint.
SuperAutobacs (now SuperAutoToyz) had a huge array of racing seats that you could sit in and 'try out'. i don't know if the seats are still there, they were a couple years ago.
for you sasquatches, alot of the racing seats are going to be hard to fit-, but nothing wrong with taking off the bottom seat cushion and running a thinner one...
+1 on the sparco wear... i need to re do my shoulder bolsters and side bolsters near the hips. those are the those wear areas.
Yea...your right, but it instills that bit more confidence that the seat is FIA "approved". I still can't find the cobra suzuka anywhere near me. I'm prolly sticking with the ZETA III L's.
Your gonna have to get an "XL" sized seat (ZETA III XL, Profi XL, Suzuka GT, EVO3) and use extra padding on the hips/lower bolsters to take up the extra space. Keep in mind when using wider seats, some customization of the rails will be necessary.
Your right though, a seat cushion change could help. It didn't in my case.
Cool - after sitting in a dump load of recaro buckets in japan I've narrowed it down to the spg xl, but still need to try out the sparco evo2 to compare....I'm 6-4, 215
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
